Ladder bar bending the diagonal link,UPDATE
#1160778
01/19/12 05:27 PM
01/19/12 05:27 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
I was under my Dister last week and seen that the diagonal link is bending in the middle I do drive it on the street as well as race it several times a year, any suggestions on how to fix it? Or what to do different on the rear suspension to fix it? I fianally got around to taking a picture of the bent diagonal link, it is bent up in the middle and to the right side of the car. The picture amy not show that but that is what it looks lie to me I couldn't find this post so I started another one Please look at this picture and tell me what you think is going on I di add some more information to the other psot on how I adjsuted the diagonal link the last time I put it in, I had to replace it when the ladder bar mounts broke off of the 8 3/4 because of one of the hiem joints in the original link was frozen up and broke off when I treid to adjust it putting it back in the car I had a truck Dana 60 cut down locally and there is around a 1/2 inch toe in on the new set up I'm taking the rear end out now and taking it to Dutchmen in Portland to have that corrected, I'll check the link for straighteness and call 1/4 Max(all thier parts) and ask them the way they want the link installed and adjusted and how to set the ladder bars up in the car as far as straightness
Re: Ladder bar suspension bending the diagonal link
[Re: Quicktree]
#1160781
01/19/12 06:22 PM
01/19/12 06:22 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I run one on my street car and never had that problem. Are the joints on the diag free without any binds ? Are the joints on the bars worn ?
6.50 @105.26
[Re: moparx]
#1160785
01/19/12 11:07 PM
01/19/12 11:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I run 1 1/8 CM and put a gusset on the rear ladder bar bracket(its too far out in space for any side loading)
[Re: MR_P_BODY]
#1160786
01/20/12 02:01 AM
01/20/12 02:01 AM
I made mine from 1" DOM - 1/4" thick wall because I heard of this happening.
[Re: ]
#1160787
01/20/12 02:17 AM
01/20/12 02:17 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
steet cars need panhard bars.....if you make the daigonal link better then the ladder bar bracket is next, then the gusset, then........ I have built X braces for street cars.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: rebel]
#1160789
01/20/12 04:35 AM
01/20/12 04:35 AM
Posts: 4,076 Mo.
racerx
Mo.
can you post a pic?
^^what he said^^
[Re: bigtimeauto]
#1160794
01/20/12 03:02 PM
01/20/12 03:02 PM
Posts: 4,076 Mo.
racerx
Mo.
can you post a pic?
^^what he said^^
A pic of a panhard bar?
No i was refereeing to the x brace.
[Re: MR_P_BODY]
#1160795
01/20/12 03:38 PM
01/20/12 03:38 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
We went the same route as Mr. P after we bent our track locator. Solid as a rock now! The alston bar was only 7/8 diameter.
Re: Ladder bar bending the diagonal link. UPDATE
[Re: WheelsUp73]
#1160796
02/13/12 01:38 AM
02/13/12 01:38 AM
Cab_Burge
Here is a picture of the bent diagonal link, see my first post on top of this post for information update or the other new post I started earlier today on this problem 2nd attempt to attach picture
