Rough running issues on a 318 2 bbl #1160129
01/18/12 10:14 AM
01/18/12 10:14 AM
Ontario
Mopar Boy Offline OP
Ontario
Been working on getting the 318 in the 68 Newport tuned up. Having issues with it running. Unless you baby the throttle the motor dies. If you also give it more than 60%, it bogs.
I have changes the cap, rotor, plugs, wires, and set the timing at 8 deg, new air filter and a bunch of other items that are not really related.
Question is, where do I go from here? I seem to have good spark, so I would assume fuel. Also, as the carb was apparently rebuilt this past summer prior to my owning it, I wonder if the internals are screwed.
Thoughts?
Thanks,
Robert
1969 Chrysler 300 440/727
1980 W350 Crew Cab Dually with 1997 12V Cummins & many, many goodies
1990 W250 Cummins NV5600
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160130
01/18/12 10:33 AM
01/18/12 10:33 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
From your description it sounds like the accelerator pump has dried out or incorrectly adjusted.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Rough running issues on a 318 2 bbl [Re: I_bleed_MOPAR] #1160131
01/18/12 10:40 AM
01/18/12 10:40 AM
scratchnfotraction Offline
Tim
BBD 2-v carbs are that way.
Re: Rough running issues on a 318 2 bbl [Re: scratchnfotraction] #1160132
01/18/12 10:43 AM
01/18/12 10:43 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
Time to take the carb off and rebuild it, also make sure you put in a new float. The caskets and new pump should be in the kit.
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160133
01/18/12 10:48 AM
01/18/12 10:48 AM
As said carb & need more than 8 deg initial. check A/P then float level & shoot a 2 second blast of starting fluid in each idle mixture screw hole, vac leak
Re: Rough running issues on a 318 2 bbl [Re: RapidRobert] #1160134
01/19/12 08:51 PM
01/19/12 08:51 PM
Ontario
Ontario
Thanks for the advice guys! Says what I hoped was not true! LOL
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160135
01/19/12 08:58 PM
01/19/12 08:58 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I was just curious why some one would put a 318 in a 68 NewPort?
Seems like a lot of work to go to a small block in a car that never had one. Or was it a 383? Either way those carter 2bbl bbd carbs are a breeze to rebuild.
I have mechanical Aptitude.
I can screw up anything.
Re: Rough running issues on a 318 2 bbl [Re: 268RTs4ME] #1160136
01/19/12 11:03 PM
01/19/12 11:03 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
There's no need to put in a new float unless the one in there is shown to have a leak. The float in mine was perfectly fine, and it was rebuilt (poorly) at least once before with the float level set all wrong.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160137
01/19/12 11:11 PM
01/19/12 11:11 PM
GMP440 Offline
GMP440  Offline
I also agree on the accelerator pump. Check to see your getting a good, hard shot. Also, adjust the idle mixture screws for a good curb idle in gear.
Re: Rough running issues on a 318 2 bbl [Re: scratchnfotraction] #1160138
01/20/12 07:51 AM
01/20/12 07:51 AM
places
79powerwagon Offline
places
Tim
I HATE BBD carbs. Of all of them that I've had over the decades, only ONE of them worked properly, and no amount of rebuilding will correct anything on them!
There was someone, this past summer, selling brand new ones. You'd be way ahead doing this, and even further ahead if you found a 2v Stromberg instead. Of course, 4v is the real ticket, but if you insist on 2v, the Stromberg is a better Mopar carb.
To the poster stating no small blocks in C bodies- you sir, are wrong. Maybe not originally in THAT particular model and year, but there are PLENTY of small block and /6 C bodies made!
Re: Rough running issues on a 318 2 bbl [Re: 79powerwagon] #1160139
01/20/12 12:36 PM
01/20/12 12:36 PM
Ontario
Ontario
No, it is a 318/904. It was a 383/727 though. Why change it to a small block? Beyond my comprehention as to why they would go through the hassle! Not to mention the casting date says 1985!? It did allow me to get a decent deal on it though!
Either way, I want to stay 2 barrel for the time being as the motor wont be in there for more than a year. Just have to save up some more funds and then it will go under the knife after the parts have been collected. If I go to a 4 barrel, then I need to get intake pan, manifold, etc. For where I am going, makes more sense to just get it driveable for the least amount.
I have also gone down this new carb road. Makes the most sense.
Where would I buy a new one and how much CFM do I need for a stock 318? I was looking on Summit and found these. Would either work? Or is there a better one I should consider?
http://www.summitracing.com/parts/HLY-64-1183/
http://www.summitracing.com/parts/HLY-64-1169/
Thanks,
Re: Rough running issues on a 318 2 bbl [Re: Secret Chimp] #1160140
01/20/12 12:39 PM
01/20/12 12:39 PM
Ontario
Ontario
Sadly, I do have leaks in the carb. It is draining out of I believe the linkage and onto the intake manifold.
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160141
01/20/12 12:52 PM
01/20/12 12:52 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
For the price of a kit, the BBD is one of the easiest carbs to rebuild ! Think you would be money ahead doing that, over buying another one that may or may not be any better than the one you have.
I have always found, especially with stock motors, that if you rebuild it according to the factory instructions (or those included with the kit), you usually end up with something very very close to perfect for your application.
Have done that with Thermoquads over the years too . . . always had em work great !! With a bit of time, and reading (go figure - read the instructions !!), you should be able to get the carb you have on the car now, running like a top !!
Why take a big block drivetrain out of a C body and replace it with a small block drivetrain ? Come on, you get the big block for another project, and still have a running/driving C body ! . . . bought a 69 Chrysler 300 like that . . . it did get the 440 later on though !!
Hope it works out for you . . .
Cheers
Mark
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160142
01/20/12 01:46 PM
01/20/12 01:46 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
If it idles steady and stumbles when you crack the throttle, YES, it's the accellerator pump.
BUT a bad accellerator pump won't create an idle that dies.
Try looking down the carb, engine not running, and cracking the throttle to see a healthy squirt of gas.
Otherwise, it sounds like a needle/seat issue if there's fuel visibly drooling out of the card.
AND/OR a bad vacuum leak. Which can be as simple as a blown base gasket of rotted out vacuum hoses.
Do a rebuild, replace old rubber vacuuum hoses and be done.
Re: Rough running issues on a 318 2 bbl [Re: Dean_Kuzluzski] #1160143
01/20/12 03:26 PM
01/20/12 03:26 PM
Eugene, Oregon
Eugene, Oregon
If you're still scratching your head over this, you can have the BBD off of my Coronet when I'm done with my four barrel swap in a couple of weeks. It's a non-emissions carb so it has none of the junk that made them pains in the butt. Always works perfectly for me.
Re: Rough running issues on a 318 2 bbl [Re: Secret Chimp] #1160144
01/20/12 04:18 PM
01/20/12 04:18 PM
P
Paul_Fancsali Offline
P
Check for a intake leak around the manifold base 318's are good for that. Also the carb was designed for spark emission control. It is too lean and I would assume does not have a O2 sensor in exhaust. Get another 2 bbl I have several but I never had a real problem with rebuilding them. Stay away from a 71 model it is a rochester design hard to get parts. By the way you did check the heat passage in manifold they love to plug up
Re: Rough running issues on a 318 2 bbl [Re: Paul_Fancsali] #1160145
01/20/12 07:18 PM
01/20/12 07:18 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
CHECK also if the intake exh heat crossover is plugged....I will bet it is.
Re: Rough running issues on a 318 2 bbl [Re: dOoC] #1160146
02/03/12 10:30 AM
02/03/12 10:30 AM
Ontario
Ontario
OK. I have battled over the last few weeks what I want to do. I ended up deciding to just wait and collect some funds, and do it right. Put on a 4 barrel and call it a day. If I am going to do it, may as well do it right.
Thanks for all of the input folks. Again, you have all kept me on the right course!
Re: Rough running issues on a 318 2 bbl [Re: Secret Chimp] #1160147
02/03/12 10:31 AM
02/03/12 10:31 AM
Ontario
Ontario
Thank you very much for the offer. Most generous of you!
Re: Rough running issues on a 318 2 bbl [Re: Mopar Boy] #1160148
02/03/12 11:59 AM
02/03/12 11:59 AM
dont forget to bump that initial up!
