Re: Tubes Needed for MT ET Streets (Bias Ply)?
[Re: 67Satty]
#1152942
01/08/12 05:57 PM
01/08/12 05:57 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Yea I had a set of old 32x19.5 Mickeys, and those things would NOT hold air worth a crap, seemed like the bead on the tire was super short, they just wouldnt seal on the Craiger Super Tricks I had... Mickey does make natural rubber tubes for your tires.. http://www.summitracing.com/parts/MTT-9553/
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: 67Satty]
#1152945
01/08/12 06:58 PM
01/08/12 06:58 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
They work without tubes but they will leak down after a few days, hoosier QTPs hold air better imo. Also tubes make the sidewalls stiffer, but weigh more.
"Just a Bracket car dressed up like a streetcar"
[Re: 67Satty]
#1152946
01/08/12 07:05 PM
01/08/12 07:05 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I'm thinking I don't need them but thought I would ask here.
They will be the 28X11.50-15 (roughly a 9X28" on a 15X7 cop rim) if that matters.
Thanks!
I never ran tubes, but you have to keep your eye on the pressure. I had to re-fill them once a week.
[Re: 67Satty]
#1152948
01/08/12 08:11 PM
01/08/12 08:11 PM
Posts: 361 Canada
onig
Canada
The bead area on the MT ET Streets are terrible. You may have to prep them to make them seal. Cut off all the little nubs. Like others said, keep an eye on the pressure and you should be OK.
69 Dart
[Re: 67Satty]
#1152950
01/08/12 10:04 PM
01/08/12 10:04 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I've wore out three sets of M/T ET Street tires on mu Duster so far, two sets of new tires and one set of used tires, the new ones didn't need any special prep to make them keep air in them ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) The one used set wouldn't hold air worth a crap until I followed what was recommended on here for sealing them, use Dawn dish washing soap straight out of the bottle and coat the intire inside of the tires, let them sit over night to soak in before remounting and reinflating them ![](/ubbthreads/images/graemlins/thumbs.gif) Works good, last a long time ![](/ubbthreads/images/graemlins/Twocents.gif)
