Tubes Needed for MT ET Streets (Bias Ply)? #1152941
01/08/12 05:22 PM
01/08/12 05:22 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I'm thinking I don't need them but thought I would ask here.
They will be the 28X11.50-15 (roughly a 9X28" on a 15X7 cop rim) if that matters.
Thanks!
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: 67Satty] #1152942
01/08/12 05:57 PM
01/08/12 05:57 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Yea
I had a set of old 32x19.5 Mickeys, and those things would NOT hold air worth a crap, seemed like the bead on the tire was super short, they just wouldnt seal on the Craiger Super Tricks I had...
Mickey does make natural rubber tubes for your tires..
http://www.summitracing.com/parts/MTT-9553/
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: 67Satty] #1152943
01/08/12 06:02 PM
01/08/12 06:02 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
a friend has that size ET streets and ran them on 8" steelwheels and 10" centerlines and it works without tubes but you have to fill them up regularly
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: 1Fast340] #1152944
01/08/12 06:27 PM
01/08/12 06:27 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
Try some High Tack on the beads ...some guy's use
soap?,but High Tack worked for me before I had tube's
also they didn't seem to move much on the rim,without
screw's.
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: 67Satty] #1152945
01/08/12 06:58 PM
01/08/12 06:58 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
They work without tubes but they will leak down after a few days, hoosier QTPs hold air better imo. Also tubes make the sidewalls stiffer, but weigh more.
"Just a Bracket car dressed up like a streetcar"
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: 67Satty] #1152946
01/08/12 07:05 PM
01/08/12 07:05 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Thanks!
I never ran tubes, but you have to keep your eye on the pressure. I had to re-fill them once a week.
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: torkrules] #1152947
01/08/12 07:39 PM
01/08/12 07:39 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I've been running them for about 3 years now without tubes. Might have to add air once or twice a year, that's it. Generally after the car sits for a while, like over the winter.
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: 67Satty] #1152948
01/08/12 08:11 PM
01/08/12 08:11 PM
Canada
onig Offline
onig  Offline
Canada
The bead area on the MT ET Streets are terrible. You may have to prep them to make them seal. Cut off all the little nubs. Like others said, keep an eye on the pressure and you should be OK.
69 Dart
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: onig] #1152949
01/08/12 08:23 PM
01/08/12 08:23 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i just soap the inside and bead sealer on the bead and on prob. brad
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: 67Satty] #1152950
01/08/12 10:04 PM
01/08/12 10:04 PM
I've wore out three sets of M/T ET Street tires on mu Duster so far, two sets of new tires and one set of used tires, the new ones didn't need any special prep to make them keep air in them The one used set wouldn't hold air worth a crap until I followed what was recommended on here for sealing them, use Dawn dish washing soap straight out of the bottle and coat the intire inside of the tires, let them sit over night to soak in before remounting and reinflating them Works good, last a long time
Re: Tubes Needed for MT ET Streets (Bias Ply)? [Re: Cab_Burge] #1152951
01/09/12 02:29 AM
01/09/12 02:29 AM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Cool! Thanks for the tips everyone!
