Re: more and more fast small blocks
[Re: fasthawk6]
#1152397
01/08/12 06:05 PM
01/08/12 06:05 PM
Posts: 2,578 sweden
1Fast340
sweden
You can have a small block mopar with stock 18 degree valve angle flow 380. Just the tightwad Mopar crowd will not spend the money.
This stuff has been available for almost 10 years and no-one will spend the coin or go to the right people to get it done.
Leon
That may be the case, but he will not have that much more in that setup than i have in my indy heads and intake plus you can still use a off the shelf header
stuff of the shelf usualy dont fit or work worth a crap anyway so i dont know what it makes for a diference
[Re: fasthawk6]
#1152398
01/08/12 06:28 PM
01/08/12 06:28 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
Nothing exotic! M/P Steel crank, Scat rods, and 11.2 -1 compression, a 590 lift M/P mechanical cam, 750 HP carb, 1 7/8 headers, 3150 lbs. (w/driver) 4700 stall Ultimate Converter, and 4.56s...Oh Yeah over 25 years of flogging the car/combo. Its now mechanical throttle-stopped down to run 11.50s on Hoosier QTPs for Street Eliminator.
[Re: W5Duster436]
#1152399
01/08/12 08:11 PM
01/08/12 08:11 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
What head are you refering to Leon?
Don't worry about it because you don't need them..
I need to keep up with the Jones's...err..I mean Clarks
[Re: fishy340]
#1152400
01/08/12 08:56 PM
01/08/12 08:56 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
mbecylinderheads go to where it says p5
Nice lookin'......ain't it????
[Re: 72demon416]
#1152402
01/08/12 09:48 PM
01/08/12 09:48 PM
jim sciortino
Trumbull,CT.
Holy crap, I didn't know that we had any head offerings capable of 460 cfm
Psssssst.....
It's capable of even more.
[Re: ademon]
#1152403
01/08/12 10:52 PM
01/08/12 10:52 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I went 10.50s (10.40 best)with a non stroked W2 363,904 and 550hp in a 68 Dart
yep it doesn't take 600hp, I went 10.40s with my stock stroke 360 in my challenger.
MR Yuck wont believe you, you must have exotic parts in it!
wuh? who said you need 600hp to do 10.50's in an a-body? Not me. But it will take a lot more work to make a 360 do than a 440.
[Re: 383man]
#1152407
01/09/12 12:40 PM
01/09/12 12:40 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Bring on the smallblocks. I'm your huckleberry Put my NA BB's up against those NA smallblocks out there, especially at the same weight Oh yeah neither of my BB are all that big either
[Re: stevet340]
#1152411
01/09/12 05:07 PM
01/09/12 05:07 PM
Posts: 1,019 Finland
mafo
Finland
fast and smallblock are relative terms... most "smallblocks" on here are well over 400 cubic inches, is that really small???
mine is just 391...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: stevet340]
#1152412
01/09/12 05:12 PM
01/09/12 05:12 PM
Posts: 3,396 Pa
Hot 340
Pa
Look at the fastest car list, even though it needs updated, and you will see what is fast and what is small...
Before I look, lemme guess, it's you.
