to sleeve or not to sleeve?? #1150490
01/04/12 05:43 PM
01/04/12 05:43 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Had fun with our new 418 last summer but at the end cracked #5 cyl. lot of $ in block prep as you know this, if all other cyl.sona check good would you sleeve # 5 and go with it, it is not all out race,street with a few weekends at the track, maybe 500hp 10.3comp. 40overbore, kinda hate to wast a lot of machine work already done but what do we think? sleeve and go or step back and punt? thanks.
Re: to sleeve or not to sleeve?? [Re: Lew] #1150491
01/04/12 05:52 PM
01/04/12 05:52 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Where is the crack?
Re: to sleeve or not to sleeve?? [Re: Lew] #1150492
01/04/12 05:52 PM
01/04/12 05:52 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
You could sonic check the block first and see if it is worth saving. Sleeving isn't that cheap because it usually distorts the adjacent cylinders, so they have to be honed with a torque plate, decked, etc. Cheaper that prepping a new block though.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: to sleeve or not to sleeve?? [Re: Dads426] #1150493
01/04/12 05:59 PM
01/04/12 05:59 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Sleeve it.
Re: to sleeve or not to sleeve?? [Re: Dragula] #1150494
01/04/12 05:59 PM
01/04/12 05:59 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
about hlf way up the cyl.in the upper side toward lifter valley.
Re: to sleeve or not to sleeve?? *DELETED* [Re: B G Racing] #1150495
01/04/12 06:01 PM
01/04/12 06:01 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Post deleted by Lew
Re: to sleeve or not to sleeve?? [Re: Lew] #1150496
01/04/12 06:03 PM
01/04/12 06:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you know that is what i wanted to hear, RIGHT!
I know I did , you already had it set in your mind what you wanted to d oand was looking for someone to agree.
That said I would sleeve the block , even if you have to do a couple more holes after the sonic check.
Re: to sleeve or not to sleeve?? [Re: B G Racing] #1150497
01/04/12 06:12 PM
01/04/12 06:12 PM
an8sec70cuda Offline
Sleeve it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: to sleeve or not to sleeve?? [Re: an8sec70cuda] #1150498
01/04/12 06:21 PM
01/04/12 06:21 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Sleeve it. I have 2 sleeves in my 499 going on 8 years now. Nothing wrong with them as long as they are done right.
Jeff
Re: to sleeve or not to sleeve?? *DELETED* [Re: JERICOGTX] #1150499
01/04/12 07:12 PM
01/04/12 07:12 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Post deleted by Sixgun
Re: to sleeve or not to sleeve?? [Re: Sixgun] #1150500
01/04/12 07:14 PM
01/04/12 07:14 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
My 340 dynoed 640HP has eight sleaves in it!
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: to sleeve or not to sleeve?? [Re: Sixgun] #1150501
01/04/12 07:15 PM
01/04/12 07:15 PM
Sleeve is good do it! One of the best drag engines I ever had --small block--had one --done right by experienced hand they are NO issue--wish other fixes were as simple and effective--really! Sleeve it , forget it, race the crud out of it!!
Re: to sleeve or not to sleeve?? [Re: Sixgun] #1150502
01/04/12 07:16 PM
01/04/12 07:16 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
If all 8 cylinders were sleeved? Probably the safest thing to do. But, a sleeve does not necessarily knock the deck out of plane.
Re: to sleeve or not to sleeve?? [Re: Leon441] #1150503
01/05/12 09:59 AM
01/05/12 09:59 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Thanks for all your reply's sounds like i can sleeve and run, i like that plan, thanks again guys.
Re: to sleeve or not to sleeve?? [Re: Leon441] #1150504
01/05/12 10:20 AM
01/05/12 10:20 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
my machine shop did 2 sleeves for me. I had cracked a cylinder on a .060 over 383 stroker. the FIRST and FIRED machine shop told me that it needed .060 to clean up, so I asked "did you check it? can it go .060?" they said "oh yea, it's good to go"
being my first build, I didn't think to ask for the sonic check sheet.
Anyway, 200 miles into it, it cracked a cylinder, so I went to my new machine shop and had them sonic check it. one other cylinder was thin besides the cracked one. Had them sleeve both holes, because 2 sleeves were cheaper than another $800 in block prep for a new block.
they told me they "kiss" the decks after the job to be sure that everything is flat and true again. only cut .005 off, basically enough to ensure the sleeve is even with the deck so that you don't run into head gasket sealing issues.
**Photobucket sucks**
Re: to sleeve or not to sleeve?? [Re: 70Cuda383] #1150505
01/05/12 10:21 AM
01/05/12 10:21 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
By the way, after fixing the block with sleeves, rebuilding the engine, this time with eddy heads, it made 505 hp 535 tq, and I've got 4,000 street miles on it.
no problems!
