Re: to sleeve or not to sleeve??
[Re: Lew]
#1150492
01/04/12 05:52 PM
01/04/12 05:52 PM
Posts: 1,443 Maryland
Dads426
Maryland
You could sonic check the block first and see if it is worth saving. Sleeving isn't that cheap because it usually distorts the adjacent cylinders, so they have to be honed with a torque plate, decked, etc. Cheaper that prepping a new block though.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Lew]
#1150496
01/04/12 06:03 PM
01/04/12 06:03 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
you know that is what i wanted to hear, RIGHT!
I know I did , you already had it set in your mind what you wanted to d oand was looking for someone to agree.
That said I would sleeve the block , even if you have to do a couple more holes after the sonic check.
[Re: B G Racing]
#1150497
01/04/12 06:12 PM
01/04/12 06:12 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Sleeve it.
[Re: Sixgun]
#1150500
01/04/12 07:14 PM
01/04/12 07:14 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
My 340 dynoed 640HP has eight sleaves in it!
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
[Re: Sixgun]
#1150501
01/04/12 07:15 PM
01/04/12 07:15 PM
Sleeve is good do it! One of the best drag engines I ever had --small block--had one --done right by experienced hand they are NO issue--wish other fixes were as simple and effective--really! Sleeve it , forget it, race the crud out of it!!
[Re: Sixgun]
#1150502
01/04/12 07:16 PM
01/04/12 07:16 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
If all 8 cylinders were sleeved? Probably the safest thing to do. But, a sleeve does not necessarily knock the deck out of plane.
[Re: Leon441]
#1150504
01/05/12 10:20 AM
01/05/12 10:20 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
my machine shop did 2 sleeves for me. I had cracked a cylinder on a .060 over 383 stroker. the FIRST and FIRED machine shop told me that it needed .060 to clean up, so I asked "did you check it? can it go .060?" they said "oh yea, it's good to go"
being my first build, I didn't think to ask for the sonic check sheet.
Anyway, 200 miles into it, it cracked a cylinder, so I went to my new machine shop and had them sonic check it. one other cylinder was thin besides the cracked one. Had them sleeve both holes, because 2 sleeves were cheaper than another $800 in block prep for a new block.
they told me they "kiss" the decks after the job to be sure that everything is flat and true again. only cut .005 off, basically enough to ensure the sleeve is even with the deck so that you don't run into head gasket sealing issues.
**Photobucket sucks**
[Re: 70Cuda383]
#1150505
01/05/12 10:21 AM
01/05/12 10:21 AM
70Cuda383
Marysville, O-H-I-O
By the way, after fixing the block with sleeves, rebuilding the engine, this time with eddy heads, it made 505 hp 535 tq, and I've got 4,000 street miles on it.
no problems!
