Shifter option for a manual to floor auto swap #1147205
12/31/11 01:12 AM
12/31/11 01:12 AM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
First off I know .. I know.. what the heck are you doing changing from a manual to and auto, but what are the best options that people have had experience with when doing this conversion - cost conscientious and this will only be a cruise, no serious racing. No console, just the 4 speed hole. Thanks
-C
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147206
01/01/12 01:16 AM
01/01/12 01:16 AM
Michigan, USA
Michigan, USA
No suggestions?
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147207
01/01/12 01:25 AM
01/01/12 01:25 AM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Changed the tunnel out on barracuda when I was a teen. USed to be a 3sp and changed it to an auto... back then the parts were easy to find in the salvage yard to make it look stock using all OEM parts. Now if I were to do it, I'd use an aftermarket shifter and not worry about the tunnel... or the console for that matter.
Re: Shifter option for a manual to floor auto swap [Re: camdog440] #1147208
01/01/12 02:19 AM
01/01/12 02:19 AM
Michigan, USA
Michigan, USA
So what shifter would use look into?
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147209
01/01/12 02:54 AM
01/01/12 02:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Better figure out what trans first
Re: Shifter option for a manual to floor auto swap [Re: MR_P_BODY] #1147210
01/01/12 05:02 PM
01/01/12 05:02 PM
Michigan, USA
Michigan, USA
727 or 727 with GV o/d.
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147211
01/01/12 06:21 PM
01/01/12 06:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I went with a B&M Quick Silver for my street rod...
cant really say I'd go that way again due to the clumsy
way it has to go to N or P, you have to lift the shifter
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147212
01/01/12 06:33 PM
01/01/12 06:33 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
for no console there are a few "shifters from hell" that will work....as I call them...lift up...lock...pull back..press down...squeeze handle...etc
Re: Shifter option for a manual to floor auto swap [Re: terzmo] #1147213
01/01/12 07:28 PM
01/01/12 07:28 PM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
Leave the hump in...in case you ever want to put it back. Then get any rachet shifter that you like and install it. Dont forget about the neutral safety switch and harness too.
HR20.
Re: Shifter option for a manual to floor auto swap [Re: HotRod20] #1147214
01/01/12 09:51 PM
01/01/12 09:51 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
My '64 Savoy has the 4-speed hump; made a plate to adapt a Cheetah shifter and mount some switches & fuse block. It screws into the the holes previously used for the shifter boot ring, and it's very solid because the shifter itself strengthens the 3/16" aluminum plate.
In the pic, you can see where the cable goes through the carpet & a grommeted hole in the tunnel; the black "tube" is the wiring, which will also go through & under the carpet when I finish it up. It's all easily serviceable. If the car had buckets I could move the shifter back an inch or two, but it's comfortable where it is, and easily undone if the car ever goes back to a 4-speed.
Re: Shifter option for a manual to floor auto swap [Re: topside] #1147215
01/01/12 09:52 PM
01/01/12 09:52 PM
A collage of whims
A collage of whims
Right side view.
Re: Shifter option for a manual to floor auto swap [Re: HotRod20] #1147216
01/01/12 10:01 PM
01/01/12 10:01 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
HR20.
And you will need to swap the starter relay so you can wire in the NSS.
Topside- very nice work.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Shifter option for a manual to floor auto swap [Re: topside] #1147217
01/08/12 01:03 AM
01/08/12 01:03 AM
Michigan, USA
Michigan, USA
Right side view.
Pardon the ignorance, but is the plate necessary and also what is the button for on the Cheetah shifter?
-C
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147218
01/08/12 02:22 AM
01/08/12 02:22 AM
A collage of whims
A collage of whims
No pardon needed; I used the mounting plate to adapt the Cheetah mounting pattern to the 4-speed hump and to be a base that I could mount the add-on switches and fuse block to. That way it's all easy to reach and service. The stock hump location is too far forward for this shifter. Need some kind of plate anyway to blank off that big hole in the floor. The shifter itself actually reinforces the plate, which mounts using the 4 screw holes for the 4-speed's shifter boot ring.
All Cheetahs have that button as far as I know; I use it for the line-loc, but it could be used for a transbrake or anything that uses a momentary switch.
Re: Shifter option for a manual to floor auto swap [Re: topside] #1147219
01/08/12 07:56 PM
01/08/12 07:56 PM
Michigan, USA
Michigan, USA
2 more questions - Is the Cheetah worth the money? Is there an alternative you are aware of that would work with the stock hole location (lokar?)
Thanks for the help
-C
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147220
01/08/12 10:54 PM
01/08/12 10:54 PM
A collage of whims
A collage of whims
I used a Cheetah in this car because there's one in my other car and I like it. I doubt there's anything with a long enough handle to use in the 4-speed shift tower location.
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147221
01/10/12 12:09 AM
01/10/12 12:09 AM
Commack NY USA
2
2Red2LoudDodge Offline
Commack NY USA
I had a BM ratchet shifter that in less than two years the cable had melted three times and one pulled out of the end cap. The fifth cable was binding before I could finish the install. Since the car was for cruising and not racing, I went with a twelve inch Lokar floor mount shifter. I used many of the same holes from the ratchet shifter rather than cut more into the tranny tunnel. I closed up the install with the boot and trim ring from a non Hurst four speed. Linkage is all mechanical, solid and no more meltdowns. I think it looks pretty good too.
Re: Shifter option for a manual to floor auto swap [Re: 2Red2LoudDodge] #1147222
01/10/12 12:14 AM
01/10/12 12:14 AM
Michigan, USA
Michigan, USA
Any pictures?
Re: Shifter option for a manual to floor auto swap [Re: ramman5600] #1147223
01/10/12 03:33 PM
01/10/12 03:33 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I put a hurst v-matic in my swinger. It uses the same cable as B&M. It was pretty easy to bolt up a couple metal/rubber d-loops to keep it off the headers. It kind of loops around my starter. Never melted or had a problem, but the B&M replacement cable is on the shelf at most pep boys etc. next to the chevy valve cover dress up crapola. It came with all the shifter arms etc. to put it on a 727 or 904 or whatever.
The v-matic has a little learning curve, but I like it. Pull rings up for R lockout. Once it's in N the shifter pops up and you can pull back to D 2 1 like a regular column shifter. In N you can also push the stick down and pull back and it's a ratchet (slap) shifter- pull back two more times and you are in 1. Rev up in 1 and slap her foreward, you're chirping 2nd, do it again into D. Slap it up to N and it pops up back to regular shifting. My little 318 is just a cruiser, but who doesn't want to feel like Joe Dirt once in a while- chirpin gears- Aaah-aah-woo!
