Aluminum Vs. Factory Radiator #1145346
12/27/11 08:31 PM
12/27/11 08:31 PM
Ont. Canada
10.90 Racer Offline OP
super street
super street
Ont. Canada
On an A body. How much weight savings have you seen going to an Aluminum rad??
Re: Aluminum Vs. Factory Radiator [Re: 10.90 Racer] #1145347
12/27/11 08:41 PM
12/27/11 08:41 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i changed from a 4 row rad to a ali 2 row of similar size. the difference in weight was huge but i didn't scale it. the difference in running temp was also significant too.
Re: Aluminum Vs. Factory Radiator [Re: rebel] #1145348
12/27/11 08:52 PM
12/27/11 08:52 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I went from a six cyl factory rad to a howe 19x26 two core alum and it was 6 lbs lighter if I remember correctly. As stated it works alot better also.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Aluminum Vs. Factory Radiator [Re: 10.90 Racer] #1145349
12/28/11 02:16 AM
12/28/11 02:16 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Would you Guys happen to know what the fluid volume difference (if any) would be?
Mo' Farts
Moderated by "tbagger".
Re: Aluminum Vs. Factory Radiator [Re: Grizzly] #1145350
12/28/11 04:11 AM
12/28/11 04:11 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Yeah - to compare apples to apples you would have to compare the radiators full of coolant.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Aluminum Vs. Factory Radiator [Re: Grizzly] #1145351
12/28/11 04:23 AM
12/28/11 04:23 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
this i do know. they were the same. the 4 row i swapped away from had small cores & the ali has 2 large cores & the tanks were about equal. my rad swap was almost an exact copy, they were made to fit the same mount real easy.
Re: Aluminum Vs. Factory Radiator [Re: 10.90 Racer] #1145352
12/28/11 10:15 AM
12/28/11 10:15 AM
an8sec70cuda Offline
I replaced my factory 26" copper radiator w/ a big Griffin aluminum radiator. The radiator itself may have been lighter, but it holds a lot more water. I wanted to get the car to run cooler though, so I didn't care. It was some of the best money I spent as far as street driving.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum Vs. Factory Radiator [Re: an8sec70cuda] #1145353
12/28/11 10:20 AM
12/28/11 10:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ithink once it's filled there isn't much difference in weight. But a 2 core Aluminum will cool as well as a 4 core copper. The cores are much larger. I got mine off of e-bay for $190 w/ stock b-body mounts and trans line hook-ups. So far it runs nice and cool.
Coming soon!!!!
Re: Aluminum Vs. Factory Radiator [Re: Mr.Yuck] #1145354
12/28/11 01:08 PM
12/28/11 01:08 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My alum holds more water then my factory rad did so it is heavier over all. But worth it, I can drive my car in rush hour and not over heat.
Re: Aluminum Vs. Factory Radiator [Re: 1967dartgt] #1145355
12/28/11 01:21 PM
12/28/11 01:21 PM
Az
Crizila Offline
Crizila  Offline
Az
Given the same outside demensions, the 2 row aluminum and the 3 - 4 row brass are close in coolant capacity. The aluminum is more efficient and a lot lighter.
Fastest 300
