Re: Aluminum Vs. Factory Radiator
[Re: rebel]
#1145348
12/27/11 08:52 PM
12/27/11 08:52 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I went from a six cyl factory rad to a howe 19x26 two core alum and it was 6 lbs lighter if I remember correctly. As stated it works alot better also.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Grizzly]
#1145351
12/28/11 04:23 AM
12/28/11 04:23 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Would you Guys happen to know what the fluid volume difference (if any) would be?
this i do know. they were the same. the 4 row i swapped away from had small cores & the ali has 2 large cores & the tanks were about equal. my rad swap was almost an exact copy, they were made to fit the same mount real easy.
[Re: 10.90 Racer]
#1145352
12/28/11 10:15 AM
12/28/11 10:15 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
I replaced my factory 26" copper radiator w/ a big Griffin aluminum radiator. The radiator itself may have been lighter, but it holds a lot more water. I wanted to get the car to run cooler though, so I didn't care. It was some of the best money I spent as far as street driving.
[Re: Mr.Yuck]
#1145354
12/28/11 01:08 PM
12/28/11 01:08 PM
1967dartgt
Hilltown Pa
My alum holds more water then my factory rad did so it is heavier over all. But worth it, I can drive my car in rush hour and not over heat.
[Re: 1967dartgt]
#1145355
12/28/11 01:21 PM
12/28/11 01:21 PM
Posts: 7,506 Az
Crizila
Az
Given the same outside demensions, the 2 row aluminum and the 3 - 4 row brass are close in coolant capacity. The aluminum is more efficient and a lot lighter.
Fastest 300
