2000 Dodge Intrepid Died while running.
#1145264
12/27/11 06:52 PM
12/27/11 06:52 PM
Posts: 93 northern wis
crazy_bee
northern wis
Hey guys I could use some help here. My mother in law was driving on the highway 55 mph when the motor lost power and when she pulled over it wanted to die and not rev up. She tried to start it and it would start but does not stay running when you try to put it in gear. Last year I replace the battery and cleaned the cables to. I also replaced the starter at the same time. It has run fine till today. Anything I should look for? If I remember it has the 3.0 in it but I could be wrong. Thanks in advance Richie R
Re: 2000 Dodge Intrepid Died while running.
[Re: teflon]
#1145269
12/28/11 05:36 PM
12/28/11 05:36 PM
crazy_bee
northern wis
Well I got to hear it run but it only runs on 4 or 5 cylinders at idle. You can give it gas and then it backfires on the passenger side bank of cylinders and then revs up. It seems to run all 6 then. Could it be a bad coil or sparkplug? Yes it is the 2.7 motor with 160,000 miles on it. Tank is full of gas also. So Iam going to pull the spark plugs and check the coils. Thanks Rich ![](/ubbthreads/images/graemlins/frown.gif)
