2000 Dodge Intrepid Died while running. #1145264
12/27/11 06:52 PM
12/27/11 06:52 PM
northern wis
crazy_bee Offline OP
northern wis
Hey guys I could use some help here. My mother in law was driving on the highway 55 mph when the motor lost power and when she pulled over it wanted to die and not rev up. She tried to start it and it would start but does not stay running when you try to put it in gear. Last year I replace the battery and cleaned the cables to. I also replaced the starter at the same time. It has run fine till today. Anything I should look for? If I remember it has the 3.0 in it but I could be wrong.
Thanks in advance
Richie R
Re: 2000 Dodge Intrepid Died while running. [Re: crazy_bee] #1145265
12/27/11 07:54 PM
12/27/11 07:54 PM
ill
dennismopar73 Offline
ill
Bang on the tank by the pump , see if it starts run , possible fuel pump
just a try,
Re: 2000 Dodge Intrepid Died while running. [Re: crazy_bee] #1145266
12/27/11 08:53 PM
12/27/11 08:53 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
2000 would be the dreaded 2.7 or the less dreaded 3.2 or 3.5. My own 3.2 2000 intrepid went from running perfect, to barely running, but did make it 25 miles home in a matter of 1/2 hour when the fuel pump puked. Check eng light did not come on, and only clue I got was that funky lean smell before it quit rolling into driveway. Nice feature is fuel tank drain plug , by the way.
Re: 2000 Dodge Intrepid Died while running. [Re: crazy_bee] #1145267
12/27/11 09:36 PM
12/27/11 09:36 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My wife had a 2000 LHS. She called me one day and said it just died going down the road. It showed 1/4 tank of fuel but was really empty Just a thought/
Re: 2000 Dodge Intrepid Died while running. [Re: Dcuda69] #1145268
12/27/11 10:43 PM
12/27/11 10:43 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Yup, check fuel pressure.
Re: 2000 Dodge Intrepid Died while running. [Re: teflon] #1145269
12/28/11 05:36 PM
12/28/11 05:36 PM
northern wis
northern wis
Well I got to hear it run but it only runs on 4 or 5 cylinders at idle. You can give it gas and then it backfires on the passenger side bank of cylinders and then revs up. It seems to run all 6 then.
Could it be a bad coil or sparkplug? Yes it is the 2.7 motor with 160,000 miles on it. Tank is full of gas also.
So Iam going to pull the spark plugs and check the coils.
Thanks Rich
Re: 2000 Dodge Intrepid Died while running. [Re: crazy_bee] #1145270
12/28/11 08:48 PM
12/28/11 08:48 PM
northern wis
northern wis
Well I put in plugs as the ones in there were really worn. There was not much left of the plugs, 1 plug was wet so I moved the coil to a different plug and it was wet also after I started it and let it idle. So I put a new coil in and it still runs bad, like 4 or 5 cyls at idle. And it makes a clattering sound on the passenger bank of cyls. I think it is icky inside that valve cover. So I just stopped working on it for now.
