vac advance on street car? #1145040
12/27/11 01:58 PM
12/27/11 01:58 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Hello, I've been reading a lot about the need for Vacuum advance distributor for a street car. But I swear 90% of the BB street builds I see have a MSD Pro Billet non vac advance distributor. So do I need the vacuum advance? This is a mild 500hp BB street build. Thanks
Re: vac advance on street car? [Re: 70VcodeCoronetRT] #1145041
12/27/11 02:01 PM
12/27/11 02:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They do help for fuel mileage when your cruising
Re: vac advance on street car? [Re: 70VcodeCoronetRT] #1145042
12/27/11 02:08 PM
12/27/11 02:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I can't recall the last time I hooked up a vac advance...
Coming soon!!!!
Re: vac advance on street car? [Re: Mr.Yuck] #1145043
12/27/11 02:12 PM
12/27/11 02:12 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Then your wasting fuel.... Unfortunately most serious aftermarket ignitions are designed by guys with more race thinking than street thinking....
Re: vac advance on street car? [Re: MR_P_BODY] #1145044
12/27/11 02:19 PM
12/27/11 02:19 PM
Kirkland, Washington
Pacnorthcuda Offline
and part throttle response.
Re: vac advance on street car? [Re: 1_WILD_RT] #1145045
12/27/11 03:12 PM
12/27/11 03:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If so it isn't much. The last 3 engines (2x440's) had curved and welded distribs. The Supercharged 440 in my 67 coronet netted me 12mpg w/ 3.91's doing 65-70mph or so over 50+ miles. The 340 swinger w/ holley 750DP and 3.55's got over 17mpg at 65-70 and this 440-6 build w/ solid roller cam avg'd around 12-13 putting (40-45mph) on back roads to and from the track (40+ miles) How much better would a vac advance be?
Re: vac advance on street car? [Re: Pacnorthcuda] #1145046
12/27/11 03:15 PM
12/27/11 03:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i use them on my streeters. they make perfect sense, and are tunable. they help keep the combustion chambers clean and aid in fuel mileage. i used to be the "full centrifugal only" type guy but got away from that thinking years ago.
Re: vac advance on street car? [Re: lewtot184] #1145047
12/27/11 03:20 PM
12/27/11 03:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
how much does one want it to advance??
Re: vac advance on street car? [Re: Mr.Yuck] #1145048
12/27/11 03:26 PM
12/27/11 03:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
total advance in cruise mode is around 52 degrees. this will vary depending how much advance is in the vacuum can. they are marked with a number. i've used 8,9, and 10 degree units. the 8 or 9 has worked best for me.
Re: vac advance on street car? [Re: lewtot184] #1145049
12/27/11 03:35 PM
12/27/11 03:35 PM
Yep--I adjust to 52-54 total.
Re: vac advance on street car? [Re: Pacnorthcuda] #1145050
12/27/11 03:57 PM
12/27/11 03:57 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Is that too much for a 11:1+ motor
Re: vac advance on street car? [Re: Mr.Yuck] #1145051
12/27/11 04:00 PM
12/27/11 04:00 PM
It might very well be too much, depending on what fuel you're feeding it. If you get any part throttle pinging then back off.
Re: vac advance on street car? [Re: Pacnorthcuda] #1145052
12/27/11 04:27 PM
12/27/11 04:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also build my eng more toward the race mode then a cruiser even though I cruise in it 99% of the time. I just have a mech only Mallory dist and it has full advance by 1800 rpm of 38 degrees. I dont think I would want 52 or so myself with my eng and if I was that worried about gas milage I would be in the wrong hobby. Course I think race mode and that is full throttle the vacum advance dont work anyway. Ron
Re: vac advance on street car? [Re: 383man] #1145053
12/27/11 05:44 PM
12/27/11 05:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
same boat here Ron. I run 93..I have mine in full at 2k (38*) The meth/H2O injection helps a ton under load, but it won't fog until vaccuum is at zero an at cruise my vac gauge is at 20+
Re: vac advance on street car? [Re: 70VcodeCoronetRT] #1145054
12/27/11 05:51 PM
12/27/11 05:51 PM
Meh,
Haven't run vacuum advance in quite a few years now.
The last 318/360 headed motor that we pulled apart that I had run this way looked clean as a whistle on the tops of the pistons and would pull down decent mileage for what it was.
The 440 used to get 14-15 mph going down the Interstate at 70mph with 3.23 gears, .528 mechanical, headers and Holley 750.
Re: vac advance on street car? #1145055
12/27/11 06:13 PM
12/27/11 06:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if you can use it, then use it. your MPG will be slightly better.
Re: vac advance on street car? [Re: mikemee1331] #1145056
12/27/11 06:37 PM
12/27/11 06:37 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
There was a pretty good thread about this a while back. Try a search.
Depending on how it is hooked up, can help with mileage, cooling, etc.
383, Hemi 4-Speed, AlterKtion, D60
Re: vac advance on street car? [Re: 70VcodeCoronetRT] #1145057
12/27/11 06:39 PM
12/27/11 06:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It becomes a pain if you have advertised dura. at 300 or more.
Re: vac advance on street car? [Re: buildanother] #1145058
12/27/11 08:10 PM
12/27/11 08:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not really a street motor at that point now is it?
Don't be the exception.
Re: vac advance on street car? [Re: Supercuda] #1145059
12/27/11 08:47 PM
12/27/11 08:47 PM
chicagoland,usa
chicagoland,usa
Mine was. Did a great job testing parked car alarms too.
