Hotchkis/Firm feel question
#1144269
12/26/11 01:26 PM
12/26/11 01:26 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I have a Hotchkis TVS on my Dart GTS. It was amazing how much the steering "firmed up" with just the TVS installed but it is still too loose for my liking. I don't run autocross (mostly because the closest place to run is at least an hour away)but I do want a more positive response from the box. I read a few older posts on this subject that all went to a discussion about the fast ratio pitman arm from firm feel. My question is, since that got changed out with the TVS how does the Hotchkis equipment work with a FF stageII chuck? Would you use a stage2 or a stage 3 with this suspension if you don't race the car? Any Hotchkis guys care to weigh in? Also, when it is mentioned that "the feel is more like a newer car" name a car...does a stage 2 chuck on my Dart feel like an 06 Charger RT in terms of "stiffness" at the steering wheel? I have a stock steering wheel by the way.
Driving modern convenience in classic beauty
Re: Hotchkis/Firm feel question
[Re: Kern Dog]
#1144272
12/27/11 01:00 AM
12/27/11 01:00 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I have the Fast Ratio idler and pitman arms on the Charger along with a stage 3 steering box. There is still some slack. My 2007 truck has none though. I wonder if it is possible to get zero slack and instant response from these old systems though. Case in point: Driving in a straight line at 45 mph I can turn the wheel a few degrees each side of center before the car responds. This is with a fully rebuilt suspension. NEW tie rod ends, bushings, ball joints, everything. Once it is past the slack, its great...
What about the coupler at the bottom of the steering column? That can wear out too...
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: dart1962_440]
#1144274
01/01/12 04:03 PM
01/01/12 04:03 PM
Posts: 659 Regina, SK, Canada
charger
Regina, SK, Canada
Are you sure its not the steering box/k-frame flex causing the delay/slop?
that would be my guess...I ran a stage 3 box,the fast ratio pitman, new coupler; new EVERYTHING, and there was is little slop stillright at the top of the wheel in either direction.
I had read somewhere that it could be eliminated by welding in some gussets to keep it from flexing, but I never tried.
[Re: charger]
#1144275
01/02/12 04:00 AM
01/02/12 04:00 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
I think e booger had a cheap firm feel upgrade. Check other threads or Mopar Action. The k member stiffening helps. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
