Hotchkis/Firm feel question #1144269
12/26/11 01:26 PM
12/26/11 01:26 PM
Sacramento, Ca
Darius Offline OP
Darius  Offline OP
Sacramento, Ca
I have a Hotchkis TVS on my Dart GTS. It was amazing how much the steering "firmed up" with just the TVS installed but it is still too loose for my liking.
I don't run autocross (mostly because the closest place to run is at least an hour away)but I do want a more positive response from the box.
I read a few older posts on this subject that all went to a discussion about the fast ratio pitman arm from firm feel.
My question is, since that got changed out with the TVS how does the Hotchkis equipment work with a FF stageII chuck?
Would you use a stage2 or a stage 3 with this suspension if you don't race the car?
Any Hotchkis guys care to weigh in?
Also, when it is mentioned that "the feel is more like a newer car" name a car...does a stage 2 chuck on my Dart feel like an 06 Charger RT in terms of "stiffness" at the steering wheel? I have a stock steering wheel by the way.
Driving modern convenience in classic beauty
Re: Hotchkis/Firm feel question [Re: Darius] #1144270
12/26/11 06:21 PM
12/26/11 06:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have a stage III in my Dart Conv. with stock diameter wheel. I think that would be fine. Especially with the stock diameter steering wheel. Not real stiff.
Most all people that I've seen get the stage II feel they could/should have go one notch stiffer at least.
So many factors like your tires, steering wheel diameter, and personalized preference... Very tough to make recommendations.
Re: Hotchkis/Firm feel question [Re: Darius] #1144271
12/27/11 12:31 AM
12/27/11 12:31 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have the Fast Ratio idler and pitman arms on the Charger along with a stage 3 steering box. There is still some slack. My 2007 truck has none though. I wonder if it is possible to get zero slack and instant response from these old systems though. Case in point: Driving in a straight line at 45 mph I can turn the wheel a few degrees each side of center before the car responds. This is with a fully rebuilt suspension. NEW tie rod ends, bushings, ball joints, everything. Once it is past the slack, its great...
Re: Hotchkis/Firm feel question [Re: Kern Dog] #1144272
12/27/11 01:00 AM
12/27/11 01:00 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
What about the coupler at the bottom of the steering column? That can wear out too...
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Hotchkis/Firm feel question [Re: Secret Chimp] #1144273
12/27/11 11:09 AM
12/27/11 11:09 AM
dart1962_440 Offline
Are you sure its not the steering box/k-frame flex causing the delay/slop?
Re: Hotchkis/Firm feel question [Re: dart1962_440] #1144274
01/01/12 04:03 PM
01/01/12 04:03 PM
Regina, SK, Canada
charger Offline
charger  Offline
Regina, SK, Canada
that would be my guess...I ran a stage 3 box,the fast ratio pitman, new coupler; new EVERYTHING, and there was is little slop stillright at the top of the wheel in either direction.
I had read somewhere that it could be eliminated by welding in some gussets to keep it from flexing, but I never tried.
Re: Hotchkis/Firm feel question [Re: charger] #1144275
01/02/12 04:00 AM
01/02/12 04:00 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I think e booger had a cheap firm feel upgrade. Check other threads or Mopar Action. The k member stiffening helps. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: Hotchkis/Firm feel question [Re: HUSTLESTUFF] #1144276
01/02/12 04:26 PM
01/02/12 04:26 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
What about this from firmfeel:
http://www.firmfeel.com/sectorkit_a.htm
