AMC hubs on 10" small pattern spindle for conversion? #114335
09/02/08 10:25 PM
09/02/08 10:25 PM
Anonymous OP
Anonymous OP
Anybody know about this? I heard years ago that it was possible to use some sort of AMC Rambler or other model hubs on a mopar 10" drum spindle to convert to large bolt pattern. Anybody know what year and model they might be found on? I wont be running drums so i dont care about any drum swedging or mismatch problems. Thanks
JJ
Re: AMC hubs on 10" small pattern spindle for conversion? #114336
09/02/08 10:38 PM
09/02/08 10:38 PM
N
noisydart Offline
super gas
noisydart  Offline
super gas
N
I do remember this! But it was to run drums w/
big bolt 4 1/2" onto mopar 10" spindles.
If you won't be running drums, why would this be
of interest and more importantly, how easy is it
to get new front drums for say a 1972 Gremlin?
Re: AMC hubs on 10" small pattern spindle for conversion? [Re: noisydart] #114337
09/03/08 12:09 AM
09/03/08 12:09 AM
Anonymous OP
Anonymous OP
Im running a disk brake conversion using the small bolt hubs now, but figured if I could find these AMC hubs, all i would need to do is re-drill the rotors, or slot the current holes. Im wanting to open up more options on wheels, and want to do it as inexpensive as i can. Was the 72 gremlin one of them, or just thrown out there to pose a question.
Re: AMC hubs on 10" small pattern spindle for conversion? #114338
09/03/08 12:31 AM
09/03/08 12:31 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
IIRC, Gremlin hubs were the ones used. I doubt the year matters.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: AMC hubs on 10" small pattern spindle for conversion? #114339
09/03/08 04:47 PM
09/03/08 04:47 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
what are the application of the rotors for your swap? you may be able to find new rotors already drilled with the 5 on 4.5 bolt patteren such as a chevy celebrity 115 mm bolt cirle. I like the idea of the hubs you are wanting to use..
Re: AMC hubs on 10" small pattern spindle for conversion? [Re: Dakota_Don] #114340
09/03/08 08:28 PM
09/03/08 08:28 PM
Anonymous OP
Anonymous OP
They are the 90 Chev Celeb. rotors from EBC that are slotted and dimpled. I was hoping that the Javlin used the correct hubs since my uncle will have his old ones after his disk swap. I also know where there are a bunch of rambler americans locally, but havn't seen gremlins for a while.
JJ
Re: AMC hubs on 10" small pattern spindle for conversion? #114341
09/03/08 10:24 PM
09/03/08 10:24 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
So how are you going to mount calipers?
Re: AMC hubs on 10" small pattern spindle for conversion? #114342
09/04/08 07:54 AM
09/04/08 07:54 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Maybe dis?
"MOTOR TRAXX MOPAR TECHLINE
by Bob Doty
Another tip for the people that are looking for a way to convert the 4 inch bolt pattern on the front wheels to the 4-1/2" without changing out everything. This applies to drum brake cars only. Look for a drum brake AMC Gremlin. The bolt pattern is 4-1/2" and the bearings and hub will fit perfectly on the A-body spindle. Surprise, Surprise!....
Thanks -Bob Doty."
Common sense is a flower that does not grow in everybody's garden
Re: AMC hubs on 10" small pattern spindle for conversio [Re: Ron_M] #114343
09/04/08 09:55 AM
09/04/08 09:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Maybe dis?
by Bob Doty
Thanks -Bob Doty."
need more info , what drum and backing plate would one use ???
Re: AMC hubs on 10" small pattern spindle for conversio [Re: JohnRR] #114344
09/04/08 10:31 AM
09/04/08 10:31 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Unfortunately, I don't know
I found that here:
http://moparsa2z.com/web/brakes.htm
Looks like that came from somewhere else
Re: AMC hubs on 10" small pattern spindle for conversio [Re: Ron_M] #114345
09/06/08 06:11 PM
09/06/08 06:11 PM
Anonymous OP
Anonymous OP
Some good info there. Thanks. Too bad it doesn't specify whether the gremlin hubs fit the 9 or 10 inch mopar spindles. I would assume 10", but don't know.
