AMC hubs on 10" small pattern spindle for conversion?
#114335
09/02/08 10:25 PM
09/02/08 10:25 PM
Anybody know about this? I heard years ago that it was possible to use some sort of AMC Rambler or other model hubs on a mopar 10" drum spindle to convert to large bolt pattern. Anybody know what year and model they might be found on? I wont be running drums so i dont care about any drum swedging or mismatch problems. Thanks JJ
Re: AMC hubs on 10" small pattern spindle for conversion?
#114336
09/02/08 10:38 PM
09/02/08 10:38 PM
noisydart
super gas
super gas
I do remember this! But it was to run drums w/ big bolt 4 1/2" onto mopar 10" spindles. If you won't be running drums, why would this be of interest and more importantly, how easy is it to get new front drums for say a 1972 Gremlin?
[Re: noisydart]
#114337
09/03/08 12:09 AM
09/03/08 12:09 AM
Im running a disk brake conversion using the small bolt hubs now, but figured if I could find these AMC hubs, all i would need to do is re-drill the rotors, or slot the current holes. Im wanting to open up more options on wheels, and want to do it as inexpensive as i can. Was the 72 gremlin one of them, or just thrown out there to pose a question.
#114338
09/03/08 12:31 AM
09/03/08 12:31 AM
Posts: 1,018 Missouri
MOBodyman
Missouri
IIRC, Gremlin hubs were the ones used. I doubt the year matters. Dallas
2012 Rallye Redline Challenger, 1st new car! 2010 Ram 1500 4wd HEMI-hauler 2014 Dodge Dart-gas saver 4 projects and a bunch of parts cars, losing interest since buying the Challenger lol 1969 Dodge Coronet 500-'gonna fix 'er up someday!'
[Re: Dakota_Don]
#114340
09/03/08 08:28 PM
09/03/08 08:28 PM
They are the 90 Chev Celeb. rotors from EBC that are slotted and dimpled. I was hoping that the Javlin used the correct hubs since my uncle will have his old ones after his disk swap. I also know where there are a bunch of rambler americans locally, but havn't seen gremlins for a while. JJ
#114342
09/04/08 07:54 AM
09/04/08 07:54 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
Maybe dis? "MOTOR TRAXX MOPAR TECHLINE by Bob Doty Another tip for the people that are looking for a way to convert the 4 inch bolt pattern on the front wheels to the 4-1/2" without changing out everything. This applies to drum brake cars only. Look for a drum brake AMC Gremlin. The bolt pattern is 4-1/2" and the bearings and hub will fit perfectly on the A-body spindle. Surprise, Surprise!.... Thanks -Bob Doty."
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#114343
09/04/08 09:55 AM
09/04/08 09:55 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
by Bob Doty
Thanks -Bob Doty."
need more info , what drum and backing plate would one use ???
[Re: JohnRR]
#114344
09/04/08 10:31 AM
09/04/08 10:31 AM
Ron_M
Connecticut
Unfortunately, I don't know I found that here: http://moparsa2z.com/web/brakes.htmLooks like that came from somewhere else
[Re: Ron_M]
#114345
09/06/08 06:11 PM
09/06/08 06:11 PM
Some good info there. Thanks. Too bad it doesn't specify whether the gremlin hubs fit the 9 or 10 inch mopar spindles. I would assume 10", but don't know.
