BB Oil line pics #1142912
12/24/11 01:46 AM
12/24/11 01:46 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Was hoping people could share how they plumbed their single and dual line external pick ups for their oil systems? Particularly interested in those running a World Block.
Thanks in advance, and Happy Holidays!
Alan Jones
Re: BB Oil line pics [Re: LA360] #1142913
12/24/11 11:06 AM
12/24/11 11:06 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
here's mine, pretty simple with single line.
Re: BB Oil line pics [Re: Deepockets] #1142914
12/24/11 02:09 PM
12/24/11 02:09 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Dual line swinging PU & Charlies race pan. Stock k-frame, stock mounts and power steering....street/strip car.
Ron
Re: BB Oil line pics [Re: firefighter3931] #1142915
12/24/11 02:13 PM
12/24/11 02:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pic of my old Hemi. On the B1 I run a Wescott oil pump with a single swinging -16 line.
Re: BB Oil line pics [Re: firefighter3931] #1142916
12/24/11 02:18 PM
12/24/11 02:18 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
As has been stated,,,pretty simple..
If you like drag racing, support your local track.
Re: BB Oil line pics [Re: CHAPPER] #1142917
12/24/11 02:33 PM
12/24/11 02:33 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Re: BB Oil line pics [Re: 68 HEMI GTS] #1142918
12/24/11 03:26 PM
12/24/11 03:26 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
How does your lower radiator hose fit with the oil line right there? Tim
Re: BB Oil line pics [Re: astjp2] #1142919
12/24/11 03:49 PM
12/24/11 03:49 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
pretty simple
Re: BB Oil line pics [Re: astjp2] #1142920
12/25/11 12:10 AM
12/25/11 12:10 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
isn't a issue, there is a rubber hose that will work also. not sure of the part number.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: BB Oil line pics [Re: 68 HEMI GTS] #1142921
12/25/11 01:27 AM
12/25/11 01:27 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Mine, single line with swinging pick up and remote oil filter.
Brian Dunnigan
Re: BB Oil line pics [Re: '72CudaRacer] #1142922
12/25/11 01:31 AM
12/25/11 01:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
modified Milodon pump cover. pump doesn't loose prime when there's oil trapped in the supply hose from the pan.
Re: BB Oil line pics [Re: rebel] #1142923
12/25/11 02:00 AM
12/25/11 02:00 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Titan Oil Pump, AN-20 feed!!
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: BB Oil line pics [Re: MRMOPAR] #1142924
12/26/11 01:13 AM
12/26/11 01:13 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I thought that the lines should go higher than the pump so it wont ever lose prime. Is it myth or fact?
Are their any pics with the K-member mocked up with a steering box and Headers?
Re: BB Oil line pics [Re: astjp2] #1142925
12/26/11 04:04 PM
12/26/11 04:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
Myth on the line hiegths, IMO.I 've had systems loose prime and fixed them without raising the lines They need to be airtight on the inlet side Here is one picture of one of my motors with low lines, it holds the prime
Re: BB Oil line pics [Re: Cab_Burge] #1142926
12/26/11 04:06 PM
12/26/11 04:06 PM
2nd system wih low inlet lines
Re: BB Oil line pics [Re: Cab_Burge] #1142927
12/26/11 08:17 PM
12/26/11 08:17 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
myth, mine never has a problem with priming either.
Re: BB Oil line pics [Re: 68 HEMI GTS] #1142928
12/26/11 08:32 PM
12/26/11 08:32 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Well I did have priming problems, re routed lines, replaced o-rings finally gave up and bought a Titan pump. Priming problem solved..
Re: BB Oil line pics [Re: 68 HEMI GTS] #1142929
12/26/11 08:39 PM
12/26/11 08:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Needing a guard on a table saw is a myth too, as is wearing safety goggles when grinding! Having used neither for years I'd say I'd say I'm just lucky. For the sake of a couple extra feet of line, is it worth the risk?
Re: BB Oil line pics [Re: Stanton] #1142930
12/26/11 09:40 PM
12/26/11 09:40 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when parked for a couple of weeks, my engine would loose prime every time. would wind the engine over for 20+ sec's before the guage would show signs of movement. after increasing the line so it keep a supply of oil at the pump intake you could see the guage move instantly. the only down side of this was oil would drip off the back of the head when you were checking rocker clearences.
Re: BB Oil line pics [Re: rebel] #1142931
12/26/11 10:10 PM
12/26/11 10:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I always jack up the back of the car when I check valve lash to prevent this.
