how much cam #1135025
12/15/11 10:30 PM
12/15/11 10:30 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
how much cam will i need in a low deck 512 ,13.1,cleaned up sr's,in a 3000lb,727,4.30,14x32,to run 10.00 on 100 degree day,on e-85.thanks,sam.oop's prefer solid ft.
Re: how much cam [Re: sam64] #1135026
12/15/11 11:13 PM
12/15/11 11:13 PM
fresno ca
mikeysmopars Offline
fresno ca
My pile weighs 3320 ish with a 470 low deck 295 ez heads and has comp 620 lift with 1.6 rockers and runs bottom tens, 650 lift should be plenty.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: how much cam [Re: sam64] #1135027
12/16/11 12:34 AM
12/16/11 12:34 AM
Try the old isky 616-590 grind, it's not in there catalogs anymore but they will grind it for you I think it is around 280@.050 with .616 gross lift on the intake and .590 gross lift on the exhaust side Better than the Mopar 590 grind
Re: how much cam [Re: mikeysmopars] #1135028
12/16/11 12:40 AM
12/16/11 12:40 AM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
512 in a 3200 lbs car here I have 11.3-1 compression and edelbrock performer heads and use a ultradyne .640 lift solid flat tappet cam car runs in the 10.20s i would think with your added compession,better heads and lighter wt you should be right were you want to be with a cam in that range ultradynes seem to make good power this cam was in a buddies 451 and he took it out to go with a bigger roller and really dident gain a thing.
Re: how much cam [Re: Cab_Burge] #1135029
12/16/11 12:41 AM
12/16/11 12:41 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i am running a 263/265@.050 AROUND 630LIFT 110 LS IN AT 108
CAR RUNS LOWER 10S ON 110GAS it is a predator cam
Re: how much cam [Re: dmking] #1135030
12/16/11 01:11 AM
12/16/11 01:11 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
2950lb car with my butt in the chair, 650 lift, 272@50 roller 512 does 9.4 @ 140mph. -1 heads 12.5 cr.
Re: how much cam [Re: rebel] #1135031
12/16/11 02:10 AM
12/16/11 02:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I got a custom grind cam from Dwayne Porter for my 493. Mine is a street car but I told him I like a lumpy idle and want to make alot of power. It is a solid flat tappet that is 264 and 270 @.050. Lift is right about .590 but I use 1.6 rockers and have about .630 lift. Ground on a 110 LSA and I have it in on a 106 centerline. I really like it alot. My eng is a 493 and the car weighs 3700 with me. It runs 92 pump and I race it as I drive it thru the pipes. It has run 10.70's so far. I would call Dwayne or who ever you prefer but that eng could use a nice cutom grind. Good luck , Ron
Re: how much cam [Re: 383man] #1135032
12/16/11 11:07 AM
12/16/11 11:07 AM
gregsdart Offline
gregsdart  Offline
To run 10.00 on a 100 degree day would require over 650 hp off the dyno, or there abouts. The biggest flat tappet that will work in your motor and converter combo is the direction I would head. Unported heads that are basically cleaned up will need plenty of cam to compensate. My 499 with cleaned up -1 heads at 3,000 lbs would go 9.50s with a .717 lift roller of 283/290/110 duration. You have a little less head, and want to run a flat tappet, in air that will cost you two tenths over what I ran in.
