how much cam
#1135025
12/15/11 10:30 PM
12/15/11 10:30 PM
Posts: 1,285 okla.
sam64
okla.
how much cam will i need in a low deck 512 ,13.1,cleaned up sr's,in a 3000lb,727,4.30,14x32,to run 10.00 on 100 degree day,on e-85.thanks,sam.oop's prefer solid ft.
Re: how much cam
[Re: sam64]
#1135026
12/15/11 11:13 PM
12/15/11 11:13 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
My pile weighs 3320 ish with a 470 low deck 295 ez heads and has comp 620 lift with 1.6 rockers and runs bottom tens, 650 lift should be plenty.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: how much cam
[Re: sam64]
#1135027
12/16/11 12:34 AM
12/16/11 12:34 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Try the old isky 616-590 grind, it's not in there catalogs anymore but they will grind it for you I think it is around 280@.050 with .616 gross lift on the intake and .590 gross lift on the exhaust side Better than the Mopar 590 grind
Re: how much cam
[Re: dmking]
#1135030
12/16/11 01:11 AM
12/16/11 01:11 AM
Posts: 4,647 aotearoa
rebel
aotearoa
2950lb car with my butt in the chair, 650 lift, 272@50 roller 512 does 9.4 @ 140mph. -1 heads 12.5 cr.
Re: how much cam
[Re: 383man]
#1135032
12/16/11 11:07 AM
12/16/11 11:07 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
To run 10.00 on a 100 degree day would require over 650 hp off the dyno, or there abouts. The biggest flat tappet that will work in your motor and converter combo is the direction I would head. Unported heads that are basically cleaned up will need plenty of cam to compensate. My 499 with cleaned up -1 heads at 3,000 lbs would go 9.50s with a .717 lift roller of 283/290/110 duration. You have a little less head, and want to run a flat tappet, in air that will cost you two tenths over what I ran in.
