Green wheel bearings #1133473
12/13/11 08:20 PM
12/13/11 08:20 PM
Ohio
ralphie361 Offline OP
Ohio
I am getting ready to order axles for my a body conversion and Dr. Diff has them with the green bearings pressed on as a package. The car will mainly be street, would like to be able to corner with it, as it wont be fast enough to drag race. Should I stick with the original style bearings with adjusters?
Re: Green wheel bearings [Re: ralphie361] #1133474
12/13/11 08:23 PM
12/13/11 08:23 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'd go with the Green and say good-bye to adjusting!
Re: Green wheel bearings [Re: mikemee1331] #1133475
12/13/11 08:27 PM
12/13/11 08:27 PM
Ohio
Ohio
I would love to, but I heard that they don't hold up well with excessive side loading. I don't know if its true or not. I probably won't autocross it much, but I don't want to trash new bearings if they are more geared toward drag racing.
Re: Green wheel bearings [Re: mikemee1331] #1133476
12/13/11 08:29 PM
12/13/11 08:29 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
ADJUSTING is such a PITA ....NOT !
You know what my vote is...
Re: Green wheel bearings [Re: dOc !] #1133477
12/13/11 08:39 PM
12/13/11 08:39 PM
Ohio
Ohio
Yeah, I hear ya It wasn't even the adjusting that was calling me, it was the laziness factor that the bearings were installed and I could be done 12 minutes after UPS gets here.
Re: Green wheel bearings [Re: ralphie361] #1133478
12/13/11 08:43 PM
12/13/11 08:43 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Now if Mikey thinks that "adjusting" is such a PITA .... what wood he say to a cam or converter change? ..
Re: Green wheel bearings [Re: mikemee1331] #1133479
12/13/11 09:03 PM
12/13/11 09:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yep get rid of the adjusting it is such a BIG job. Might take all of 10 -15 minutes including packing the bearings. That is ten minutes to pack and maybe five to install and adjust the end play. Plus the tapered bearing is a superior bearing set up.
Re: Green wheel bearings [Re: MoparforLife] #1133480
12/13/11 09:57 PM
12/13/11 09:57 PM
IN
ahy Offline
ahy  Offline
IN
Roller... more durable and much better for cornering loads. I bet Dr Diff would press them on for you too.
Re: Green wheel bearings [Re: dOc !] #1133481
12/13/11 10:13 PM
12/13/11 10:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
there's an advantage to a cam or converter change. i'm all about easy! like the OP said, 12 minutes after UPS drops, you're driving!
Re: Green wheel bearings [Re: mikemee1331] #1133482
12/13/11 10:25 PM
12/13/11 10:25 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I got greens when I was in High School. They make for really gear quick changes and such and I did millions of donuts "marking" my territory. Never damaged one yet. All that said I wish I had stayed with the timken bearings.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Green wheel bearings [Re: kilroy] #1133483
12/14/11 08:18 AM
12/14/11 08:18 AM
scratchnfotraction Offline
run my first set in the 68 Dart for 9 yrs before one went out and started leaking oil with the inner seals.
got a 2nd set from DrDiff and been on them 4 yrs now in my truck.
plenty of turns,power slides,burnouts,off road trail ridding,daily driveing.
i dont run inner seals the 2nd go round and no leaks or trouble with mine.
it not that it is hard or to much time to adjust stock bearings,it is the fact that they no longer make the adjuster for the stock bearing.
i couldnt find a good one so the greens filled the spot and have held up fine for me with all types of abuse on that 8 3/4 in 2 different rides at 100 miles a day daily driveing.
i will stay with greens and even save the 12$ not running the inner seals.
as far as seals,it is 2x the protection with them but I had too many when I shot that 12$ set of seals in with the BFH so it went together with out them
no leaks after 4 yrs so far
Re: Green wheel bearings [Re: scratchnfotraction] #1133484
12/14/11 10:42 AM
12/14/11 10:42 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I beeez just ... how large is THIS mean-greenie topic is gonna' be ? ...
Can the greenies be used successfully ? .... Yes. But ask yourself WHY the OEM went to these greenies NOW. Because they are CHEAPER to make and they are a simplier install .... since they do-not require the PITA "adjustment" that Mikey mentions ...
Re: Green wheel bearings [Re: ralphie361] #1133485
12/14/11 12:12 PM
12/14/11 12:12 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
have had the same set of green bearings in my dart since the mid 90's. it was a daily driver back then. lots of hard street miles on them and i have had no issues at all with them...
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Green wheel bearings [Re: abodyjoe] #1133486
12/14/11 12:27 PM
12/14/11 12:27 PM
dogdays Offline
dogdays  Offline
There's no question that tapered roller bearings are a superior design. But they may be overkill.
It's kind of like the forged vs. cast crank debate. No question the forged crank is superior but if the cast crank doesn't break or cause power loss then the forged crank is overkill.
Or, it's like hunting gophers. You can shoot successfully with a .22, but you choose a .300 Magnum.
Hundreds of millions of cars are driving on the streets of America with ball bearings on all four wheels.
Also, remember that the three most dangerous words are, "I have heard".
R.
PS: Nothing in the above post indicated that you shouldn't run real US-made tapered roller bearings if you so choose.
Re: Green wheel bearings [Re: ralphie361] #1133487
12/14/11 05:34 PM
12/14/11 05:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're buying new axles or installing disc brakes there's nothing wrong with going with the Greens but if you're changing over simply to avoid having to adjust the Timkens I say "shame on you".
Re: Green wheel bearings [Re: John_Kunkel] #1133488
12/14/11 06:32 PM
12/14/11 06:32 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
I think one is stuck with greens if going to disc brakes , you have no choice , but because you have no choice doesn't make it right .
But I agree if changing because you are too lazy to adjust them ...
Re: Green wheel bearings [Re: JohnRR] #1133489
12/14/11 06:39 PM
12/14/11 06:39 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that was my point. he's getting new axles. go with the greens and be done with it. i wasn't advocating switching over..........
Re: Green wheel bearings [Re: ralphie361] #1133490
12/14/11 10:27 PM
12/14/11 10:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've been installing Green Bearings on my cars and customers cars for close to 2 decades, not one failure EVER, and plenty of them are daily drivers, road course cars, street/track cars, dedicated track cars....Green Bearings were developed and trademarked by Chrysler as a replacement for the Tapered design decades ago....millions of production vehicles world wide ride on Green Bearings, or similar design....just a myth the design can't handle repeated side loads,....even the circle track guys are moving into Green bearing use.....Dr Diff will set you up with what you need
Re: Green wheel bearings [Re: ralphie361] #1133491
12/14/11 11:14 PM
12/14/11 11:14 PM
Ohio
Ohio
Thanks for the info and opinions guys, I appreciate it. I went with Dr. Diff axles and green bearings installed. I think they are worth a try, and If I hate them I'll press the original set up back on them. I was also thinking about trying the grand cherokee rear disc conversion, so that was another factor. Thanks again
Re: Green wheel bearings [Re: ralphie361] #1133492
12/15/11 01:40 AM
12/15/11 01:40 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am using the green bearings in my 8-3/4. Been holding up fine. Ron
