Re: Green wheel bearings
[Re: mikemee1331]
#1133476
12/13/11 08:29 PM
12/13/11 08:29 PM
Posts: 30,449 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
i'd go with the Green and say good-bye to adjusting!
ADJUSTING is such a PITA ....NOT !
You know what my vote is...
[Re: mikemee1331]
#1133479
12/13/11 09:03 PM
12/13/11 09:03 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Yep get rid of the adjusting it is such a BIG job. Might take all of 10 -15 minutes including packing the bearings. That is ten minutes to pack and maybe five to install and adjust the end play. Plus the tapered bearing is a superior bearing set up.
[Re: dOoC]
#1133481
12/13/11 10:13 PM
12/13/11 10:13 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Now if Mikey thinks that "adjusting" is such a PITA .... what wood he say to a cam or converter change? ..
there's an advantage to a cam or converter change. i'm all about easy! like the OP said, 12 minutes after UPS drops, you're driving!
[Re: mikemee1331]
#1133482
12/13/11 10:25 PM
12/13/11 10:25 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
I got greens when I was in High School. They make for really gear quick changes and such and I did millions of donuts "marking" my territory. Never damaged one yet. All that said I wish I had stayed with the timken bearings.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
[Re: kilroy]
#1133483
12/14/11 08:18 AM
12/14/11 08:18 AM
Posts: 15,487 Florida
scratchnfotraction
run my first set in the 68 Dart for 9 yrs before one went out and started leaking oil with the inner seals. got a 2nd set from DrDiff and been on them 4 yrs now in my truck. plenty of turns,power slides,burnouts,off road trail ridding,daily driveing. i dont run inner seals the 2nd go round and no leaks or trouble with mine. it not that it is hard or to much time to adjust stock bearings,it is the fact that they no longer make the adjuster for the stock bearing. i couldnt find a good one so the greens filled the spot and have held up fine for me with all types of abuse on that 8 3/4 in 2 different rides at 100 miles a day daily driveing. i will stay with greens and even save the 12$ not running the inner seals. as far as seals,it is 2x the protection with them but I had too many when I shot that 12$ set of seals in with the BFH so it went together with out them no leaks after 4 yrs so far
[Re: ralphie361]
#1133485
12/14/11 12:12 PM
12/14/11 12:12 PM
Posts: 11,079 Berlin, N.J.
abodyjoe
Berlin, N.J.
I would love to, but I heard that they don't hold up well with excessive side loading. I don't know if its true or not. I probably won't autocross it much, but I don't want to trash new bearings if they are more geared toward drag racing.
have had the same set of green bearings in my dart since the mid 90's. it was a daily driver back then. lots of hard street miles on them and i have had no issues at all with them...
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: John_Kunkel]
#1133488
12/14/11 06:32 PM
12/14/11 06:32 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
If you're buying new axles or installing disc brakes there's nothing wrong with going with the Greens but if you're changing over simply to avoid having to adjust the Timkens I say "shame on you".
I think one is stuck with greens if going to disc brakes , you have no choice , but because you have no choice doesn't make it right .
But I agree if changing because you are too lazy to adjust them ...
[Re: JohnRR]
#1133489
12/14/11 06:39 PM
12/14/11 06:39 PM
mikemee1331
bethlehem pa
that was my point. he's getting new axles. go with the greens and be done with it. i wasn't advocating switching over..........
[Re: ralphie361]
#1133490
12/14/11 10:27 PM
12/14/11 10:27 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I've been installing Green Bearings on my cars and customers cars for close to 2 decades, not one failure EVER, and plenty of them are daily drivers, road course cars, street/track cars, dedicated track cars....Green Bearings were developed and trademarked by Chrysler as a replacement for the Tapered design decades ago....millions of production vehicles world wide ride on Green Bearings, or similar design....just a myth the design can't handle repeated side loads,....even the circle track guys are moving into Green bearing use.....Dr Diff will set you up with what you need
