Page 1 of 3 1 2 3
what does a 69 Dart with a big block weigh? #1131249
12/10/11 05:59 PM
12/10/11 05:59 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi
I'm looking at a 69 Dart to replace the coronet, with a built 383 in it and a 727 auto transmission. what do these cars weight with a big block and regular interior and 727 transmission?
Ballpark would be great!
Mike
1969 Dodge Dart Swinger
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131250
12/10/11 06:09 PM
12/10/11 06:09 PM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
My small block Dart weighs 3280. It has full interior and is all steel with an 8 point cage.
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131251
12/10/11 06:10 PM
12/10/11 06:10 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Id say 3200 to 3500 max. Aluminum wheels, aluminum intake, power steering, bench seat. These things add up.
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131252
12/10/11 07:48 PM
12/10/11 07:48 PM
My 1969 Dart 383 GTS car weighed between 3100 and 3150 without the driver with front 4x15 Centerline autodrags(first generation of centerlines that where street legal, can't rememeber the exact name ) and 165SR15 tires, 10.5x29x15 M/T darg tires on Centerline 8.5x15 Autodrag rims. No heater, radio or back seat, 1 3/4 inch diameter five point chromemoly bar with 2x2x.083 chromemoly subframe connectors, stock BB radiator with a single lightweight race seat, all iron 440 motor with a 727. Fibreglas front bumper and stock steel hood, doors and fenders the Dusters are lighter
Re: what does a 69 Dart with a big block weigh? [Re: gtsdon] #1131253
12/10/11 07:51 PM
12/10/11 07:51 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
My 68 with a 383 727 8 3/4 weighed 3400 and change as it was when I first got it. with full street interior ( bench seat ) heater, etc. No roll bar.
Went 12.70 with crappy 60 foot.
I'm Gumby dammit!
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131254
12/10/11 10:34 PM
12/10/11 10:34 PM
NC
440Jim Offline
440Jim  Offline
NC
As you can see from the various posts, it will depend on exactly what you have in the car.
My 1969 Dart GTS, with a transplanted big block, 727, Dana 60, full roll cage, backhalf, but just a race interior weighs 2970+ (plus my 230). With a full interior and just a roll bar, you might be around 3200 or more.
Re: what does a 69 Dart with a big block weigh? [Re: 440Jim] #1131255
12/11/11 12:05 AM
12/11/11 12:05 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
My GTS with aluminum case 4-speed, blow proof bellhousing, Dana 60, full bucket seat interior, roll bar, frame connectors, aluminum heads, aluminum intake, iron exhaust manifolds, power drum brakes, steel wheels on the rear with soft side wall tires, centerlines on the front with Front Runners, fiberglass fenders, fiberglass front bumper and a full tank of gas weighs 3,350 w/out me in it......
If you can't handle the truth, you're living a lie.......
Re: what does a 69 Dart with a big block weigh? [Re: Big Squeeze] #1131256
12/11/11 12:34 AM
12/11/11 12:34 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Wow, your not kidding kind of all over the board. Yet much lighter then the 4040 weight of me and the coronet together.
The car I'm looking at is a 383 bench seat car with a 727 transmission and to be determined rear axle, guy was going to take a picture for me. It could be a dana, or a 8 1/4. I of course am hoping for the dana, but sounds like it is not a 8 3/4.
Mike
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131257
12/11/11 12:10 PM
12/11/11 12:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My 69 weighed 3050 without driver, ladder bar, no back seat, all steel except hood and front bumper.
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131258
12/11/11 12:31 PM
12/11/11 12:31 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Its not the same exact car but my Fully loaded 73 440 automatic Dart Sport weighed 3200# PS/PB, functioning Air, steel everything ETC.
On its diet it now weighs 2800# WO driver
Re: what does a 69 Dart with a big block weigh? [Re: Sport440] #1131259
12/11/11 12:55 PM
12/11/11 12:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
when you guys weigh your cars you have to be on a certified car scale or it probably wont be accurate. truck scales do not work.
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131260
12/11/11 01:34 PM
12/11/11 01:34 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
My ALMOST completely stock 69 383 GTS 4 speed weighed 3605 with my 190 lb. butt in the seat, 3/8 tank of fuel, spare and jack in the trunk on the scale at Stanton. Only item not stock was a Mandrel bent 2.5" exhaust system system.
Re: what does a 69 Dart with a big block weigh? [Re: JohnRR] #1131261
12/11/11 01:50 PM
12/11/11 01:50 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
68 383 GTS 4 speed convert. w/PS - 3570 w/o driver. Don't remember the amount of fuel and if it included spare tire and jack. Car scale at Tri-State Dragway.
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131262
12/11/11 01:56 PM
12/11/11 01:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
the weight dif between dart 67 to 69 is all over the place,my bud's 68 full interior sb slum heads is like 3100 with his big butt in it,i had a 68 dart sb with stupid seats the guy had in it and it weighed over 3400 without my 215lb in it! needless to say i sold that thing.
Re: what does a 69 Dart with a big block weigh? [Re: Quicktree] #1131263
12/11/11 06:15 PM
12/11/11 06:15 PM
ill
dennismopar73 Offline
ill
WHY WOULD TRUCK SCALES BE ANY DIFFERENT THAN ANY OTHER CERT SCALES??
boy this ought to be good!
Re: what does a 69 Dart with a big block weigh? [Re: dennismopar73] #1131264
12/11/11 06:17 PM
12/11/11 06:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why? because they are not calibrated for accuracy down the 100s of pounds. try it some time smart guy
Re: what does a 69 Dart with a big block weigh? [Re: Quicktree] #1131265
12/11/11 06:22 PM
12/11/11 06:22 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
A good place to weigh your car without taking it to the track is anywhere there is commerce involved with the use of the scale, as in a scrap yard where they are buying metals. They are checked by the state and must meet standards.
Getting old just means you were smarter than some and luckier than others.
Re: what does a 69 Dart with a big block weigh? [Re: Quicktree] #1131266
12/11/11 06:25 PM
12/11/11 06:25 PM
Kirkland, Washington
Pacnorthcuda Offline
umm...yes they are. There is legal requirement to certify them to +/- 20lbs (withing the weights they measure. And they are usually very accurate at lighter weights.
The Unitec company certifies our scale to +/- 10 lbs. We weight EVERY truck we build (have too) to determine tare weight.
Re: what does a 69 Dart with a big block weigh? [Re: Pacnorthcuda] #1131267
12/11/11 06:33 PM
12/11/11 06:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
well having been an over the road driver I can tell you normal big truck scales that I have seen are no where near accurate from scale to scale. and some of the cars I have seen weighed on truck scales usually are heavy compared to a certified race scale at a track.so whatever floats your boat.
Re: what does a 69 Dart with a big block weigh? [Re: Quicktree] #1131268
12/11/11 06:47 PM
12/11/11 06:47 PM
ill
ill
why? because they are not calibrated for accuracy down the 100s of pounds. try it some time smart guy [/quote
SMART GUY! I HAVE , THE SCALES I HAVE BEEN TO I CAN WEIGH A 10# BAG SUGAR ON, CLOSE ENOUGH??
MERRY CHRISTMAS
Page 1 of 3 1 2 3
