what does a 69 Dart with a big block weigh?
#1131249
12/10/11 05:59 PM
12/10/11 05:59 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi
I'm looking at a 69 Dart to replace the coronet, with a built 383 in it and a 727 auto transmission. what do these cars weight with a big block and regular interior and 727 transmission?
Ballpark would be great!
Mike
1969 Dodge Dart Swinger
Re: what does a 69 Dart with a big block weigh?
[Re: MikeyT]
#1131252
12/10/11 07:48 PM
12/10/11 07:48 PM
Posts: 43,141 Bend,OR USA
Cab_Burge
My 1969 Dart 383 GTS car weighed between 3100 and 3150 without the driver with front 4x15 Centerline autodrags(first generation of centerlines that where street legal, can't rememeber the exact name ) and 165SR15 tires, 10.5x29x15 M/T darg tires on Centerline 8.5x15 Autodrag rims. No heater, radio or back seat, 1 3/4 inch diameter five point chromemoly bar with 2x2x.083 chromemoly subframe connectors, stock BB radiator with a single lightweight race seat, all iron 440 motor with a 727. Fibreglas front bumper and stock steel hood, doors and fenders the Dusters are lighter
[Re: gtsdon]
#1131253
12/10/11 07:51 PM
12/10/11 07:51 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
My 68 with a 383 727 8 3/4 weighed 3400 and change as it was when I first got it. with full street interior ( bench seat ) heater, etc. No roll bar. Went 12.70 with crappy 60 foot.
I'm Gumby dammit!
[Re: MikeyT]
#1131254
12/10/11 10:34 PM
12/10/11 10:34 PM
Posts: 16,924 NC
440Jim
NC
As you can see from the various posts, it will depend on exactly what you have in the car.
My 1969 Dart GTS, with a transplanted big block, 727, Dana 60, full roll cage, backhalf, but just a race interior weighs 2970+ (plus my 230). With a full interior and just a roll bar, you might be around 3200 or more.
[Re: 440Jim]
#1131255
12/11/11 12:05 AM
12/11/11 12:05 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
My GTS with aluminum case 4-speed, blow proof bellhousing, Dana 60, full bucket seat interior, roll bar, frame connectors, aluminum heads, aluminum intake, iron exhaust manifolds, power drum brakes, steel wheels on the rear with soft side wall tires, centerlines on the front with Front Runners, fiberglass fenders, fiberglass front bumper and a full tank of gas weighs 3,350 w/out me in it......
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#1131256
12/11/11 12:34 AM
12/11/11 12:34 AM
MikeyT
Watertown, WI
Wow, your not kidding kind of all over the board. Yet much lighter then the 4040 weight of me and the coronet together.
The car I'm looking at is a 383 bench seat car with a 727 transmission and to be determined rear axle, guy was going to take a picture for me. It could be a dana, or a 8 1/4. I of course am hoping for the dana, but sounds like it is not a 8 3/4.
Mike
[Re: MikeyT]
#1131257
12/11/11 12:10 PM
12/11/11 12:10 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
My 69 weighed 3050 without driver, ladder bar, no back seat, all steel except hood and front bumper.
[Re: Quicktree]
#1131263
12/11/11 06:15 PM
12/11/11 06:15 PM
Posts: 2,177 ill
dennismopar73
ill
when you guys weigh your cars you have to be on a certified car scale or it probably wont be accurate. truck scales do not work.
WHY WOULD TRUCK SCALES BE ANY DIFFERENT THAN ANY OTHER CERT SCALES?? boy this ought to be good!
[Re: dennismopar73]
#1131264
12/11/11 06:17 PM
12/11/11 06:17 PM
Quicktree
why? because they are not calibrated for accuracy down the 100s of pounds. try it some time smart guy
[Re: Quicktree]
#1131265
12/11/11 06:22 PM
12/11/11 06:22 PM
Posts: 5,160 Texas
dannysbee
Texas
A good place to weigh your car without taking it to the track is anywhere there is commerce involved with the use of the scale, as in a scrap yard where they are buying metals. They are checked by the state and must meet standards.
Getting old just means you were smarter than some and luckier than others.
[Re: Quicktree]
#1131266
12/11/11 06:25 PM
12/11/11 06:25 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
umm...yes they are. There is legal requirement to certify them to +/- 20lbs (withing the weights they measure. And they are usually very accurate at lighter weights. The Unitec company certifies our scale to +/- 10 lbs. We weight EVERY truck we build (have too) to determine tare weight.
[Re: Pacnorthcuda]
#1131267
12/11/11 06:33 PM
12/11/11 06:33 PM
Quicktree
well having been an over the road driver I can tell you normal big truck scales that I have seen are no where near accurate from scale to scale. and some of the cars I have seen weighed on truck scales usually are heavy compared to a certified race scale at a track.so whatever floats your boat.
[Re: Quicktree]
#1131268
12/11/11 06:47 PM
12/11/11 06:47 PM
Posts: 2,177 ill
dennismopar73
ill
why? because they are not calibrated for accuracy down the 100s of pounds. try it some time smart guy [/quote SMART GUY! I HAVE , THE SCALES I HAVE BEEN TO I CAN WEIGH A 10# BAG SUGAR ON, CLOSE ENOUGH?? MERRY CHRISTMAS
