Page 1 of 3 1 2 3
434 W9 Small Block #1128866
12/06/11 04:26 PM
12/06/11 04:26 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
I think I'm going to put together a 434" SBM and I wanted you guys to chime in.
4.155" bore R3
4.00" stroke
6.200" rod
W9 Heads (P5007065AB)
W9 Intake (P4876162)
Cam & Compression can be anything but I'm looking to make around 700hp
Thoughts?
Re: 434 W9 Small Block [Re: Biginchmopar] #1128867
12/06/11 04:40 PM
12/06/11 04:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats it going to be used for
Re: 434 W9 Small Block [Re: MR_P_BODY] #1128868
12/06/11 05:02 PM
12/06/11 05:02 PM
Carson City, Nevada
Carson City, Nevada
Street/Strip
Just can't have Chevy's or Fords out run me.
Re: 434 W9 Small Block [Re: Biginchmopar] #1128869
12/06/11 05:22 PM
12/06/11 05:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What type of body
Re: 434 W9 Small Block [Re: MR_P_BODY] #1128870
12/06/11 05:26 PM
12/06/11 05:26 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
What fuel?
Re: 434 W9 Small Block [Re: Biginchmopar] #1128871
12/06/11 05:29 PM
12/06/11 05:29 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Why not go 4.25 stroke while your in there?
Re: 434 W9 Small Block [Re: HotRodDave] #1128872
12/06/11 05:45 PM
12/06/11 05:45 PM
Carson City, Nevada
Carson City, Nevada
71 Demon = Body
4.00" stroke is enough
The car will be setup to race and then drive it on the street once in a while.
Fuel = gas 104 or better
Re: 434 W9 Small Block [Re: Biginchmopar] #1128873
12/06/11 06:20 PM
12/06/11 06:20 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
71 Demon = Body
Why is 4.00 enough? Tall deck judging by the manifold..Why not lay the stroke to it, you have the head for it.
Re: 434 W9 Small Block [Re: Hot 340] #1128874
12/06/11 07:43 PM
12/06/11 07:43 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
71 Demon = Body
Re: 434 W9 Small Block [Re: Biginchmopar] #1128875
12/06/11 07:52 PM
12/06/11 07:52 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
440sb, 4.185 bore, 4" stroke, 11-1, w9's by ryan j, .730 roller, m1 intake, prosystems 1050 dom, 904/w brake, ford 9"/456. 71 demon, 9.61@137.91. mainly street, some strip time. want to know anything more ask. stay safe, seeya.
Re: 434 W9 Small Block [Re: Hitman340] #1128876
12/06/11 07:54 PM
12/06/11 07:54 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The only thing stroke is good for is moving your power range around. The more stroke the more you lower your RPM range.
However bore is more beneficial for making HP. If the bore is small such as 4.100 with a W9 head you sacrifice head flow from shrouding the valve. 4.155" will work but I would go bigger.
Leon
Re: 434 W9 Small Block [Re: Leon441] #1128877
12/06/11 08:28 PM
12/06/11 08:28 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Leon
This^^^^^^^
Re: 434 W9 Small Block [Re: Leon441] #1128878
12/06/11 08:31 PM
12/06/11 08:31 PM
BPE Offline
BPE  Offline
Leon
And how hard did you turn your 441 with the 4.125" crank?
Rod
Re: 434 W9 Small Block [Re: jim sciortino] #1128879
12/06/11 08:33 PM
12/06/11 08:33 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Leon
This^^^^^^^
but the stroke will help with valvetrain longevity for street duty. x3 on the bigger bore. smallblocks have been small for decades. pull out all the stops.
Re: 434 W9 Small Block [Re: BPE] #1128880
12/06/11 09:02 PM
12/06/11 09:02 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Leon
Rod
That engine had a very good head on it. The block was not an R3 and could only safely go 4.125" bore. It's not like I ordered a 4.125" stroke crank. I bought it from the original purchaser and didn't know any better. That engine was built to run with nitrous. The crank was also a Custom Billet LA Enterprises Kryptonite crank. And yes I used the crank with the next build a 457 that later was a 468. From that experience I learned boring from 4.200" to 4.245" was a really big improvement. This crank caused nightmares running a torqueflite as it made too much torque with nitrous. With the powerglide it was much better.
My point with the post was not to bash stroke. If you run two identicle displacement engines one with a displacement made up with a long stroke the other with a large bore, the short stroke large bore is going to run better. This is especially true when running a head designed around large bores. Some argue the trucks only ran up to 4.185" so that is what one should run. That deal was due to a bore limit rule.
The best deal is to have all the bore the block will go and as long a stroke as possible to facilitate a piston and rod combo that you need. But, a lot of classes are displacement limited. Thought where the poster was wanting to build a 439 he should try and do it with a larger bore.
Just my opinion.
Leon
Re: 434 W9 Small Block [Re: Leon441] #1128881
12/06/11 09:16 PM
12/06/11 09:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just my opinion.
Leon
I really think I lack in power due to
the small bore I run... when I need a freshening I
going to go with a much bigger bore to unshroud
my intakes
Re: 434 W9 Small Block [Re: Leon441] #1128882
12/06/11 09:23 PM
12/06/11 09:23 PM
BPE Offline
BPE  Offline
Just making a point that if the rest of the combo is there, you can make good power at a higher RPM with more stroke.
Rod
Re: 434 W9 Small Block [Re: Hot 340] #1128883
12/06/11 09:51 PM
12/06/11 09:51 PM
Trumbull,CT.
Trumbull,CT.
Leon
This^^^^^^^
If it was mine, I'd do a 4.220 x 4.00 447ci.
Best of both worlds.
Re: 434 W9 Small Block [Re: Biginchmopar] #1128884
12/06/11 10:00 PM
12/06/11 10:00 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
700hp should honstly be easy with 9's,mine is 4.185 bore w a 4.00 crank.I love my sm 440sb
Re: 434 W9 Small Block [Re: fishy340] #1128885
12/07/11 02:02 PM
12/07/11 02:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I agree, run all the bore you can for the most HP then run all the stroke you can to get the RPM down to a more valve spring friendly RPM. If you are cube limited then run the biggest bore allowed then stroke it to take advantage of the displacement allowed. Do you really think the NASCAR or Indy or Formula 1 guys would not run a longer stroke if they were allowed? No. They all do just like I said, run the biggest bore they can then strok it to the displacement limit. How many NASCAR guys are out there only running 330 inches because they don't need the extra stroke?
Page 1 of 3 1 2 3
