Unstable at speeds #1128043
12/05/11 04:05 PM
12/05/11 04:05 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
My 70 Challenger which has all new suspension parts is very unstable at high speeds.I want to drag race this car. Will a front sway bar help this? What about Caster/Camber settings. What settings should it have?
Like I said everything is new, but you have to "saw" the wheel to keep it going straight.
Re: Unstable at speeds [Re: moparmikethree] #1128044
12/05/11 04:09 PM
12/05/11 04:09 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Who installed all those new parts? Did it do this befor?
Seems to me, you might just need a good front end alignment.
I have mechanical Aptitude.
I can screw up anything.
Re: Unstable at speeds [Re: bboogieart] #1128045
12/05/11 04:12 PM
12/05/11 04:12 PM
The car was converted from a /6 to a 360
with aprox 450 hp. I did all of the work.
Chrysler mechanic 31 years now.
When doing alignment could not get camber where it belongs. May buy the upper control arms ( tubular with adjustment) to get it right
Re: Unstable at speeds [Re: moparmikethree] #1128046
12/05/11 04:15 PM
12/05/11 04:15 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sounds like you know what you are doing. I have only played with these so no expert. Sounds like your right about the tubular a arms.
Good Luck.
Re: Unstable at speeds [Re: moparmikethree] #1128047
12/05/11 04:55 PM
12/05/11 04:55 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
You know about the offset controll arm bushings that Moog makes? May give the camber you need much cheaper than new arms.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Unstable at speeds [Re: moparmikethree] #1128048
12/05/11 04:58 PM
12/05/11 04:58 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
How is the steering box?
Lift the car and see if you feel any play when you pull on the wheels? See if there is any excessive movement.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Unstable at speeds [Re: HemiRick] #1128049
12/05/11 05:07 PM
12/05/11 05:07 PM
Wheatfield, NY
Cuda340 Online work
Cuda340  Online Work
Wheatfield, NY
This is a good fix...
Re: Unstable at speeds [Re: Cuda340] #1128050
12/05/11 05:24 PM
12/05/11 05:24 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
You need to:
1) Upgrade to properly rated torsion bars, if you have not done so already. (1970 you could get the 340 performance package which used 383 bars, I would copy that)
2) Buy the moog offset uppers. (You have to install them opposite the instructions though)
3) Check for bumpsteer and shim/slot/gusset the steering mount. Also I think Firm Feel is making an add-on brace for the bottom of the sector shaft on the box.
4) Is the box rebuilt? If not get a rebuilt box from Steer N Gear or Firm Feel.
5) Replace your strut rods. You do not need high dollar adjustables, just the the 30% oversized ones.
6) Pot coupler. The steering pot coupler can wear if left open and dry for extended periods. This will cause slop between the steering wheel and the actual imput on the box. Check for play and replace/repair if needed.
7) Alignment. For handling, you want +3.0 caster and -.5 camber but this is not always possible. Get as much + caster as possible while keeping negative camber.
There is also an adjustment that can be made for dead neurtal, where the box should basically be unassisted if going straight ahead, check the FSM for specs.
Re: Unstable at speeds [Re: moparmikethree] #1128051
12/05/11 05:29 PM
12/05/11 05:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You mean you can't get enough positive caster, right. Not camber.
Exactly right, invest in some Firm Feel upper control arms, they made a world of difference on my 71.
My black 74 has the offset bushings, the FF upper arms made way more difference ,gave me like 5 degrees of positive caster.
Re: Unstable at speeds [Re: Challenger 1] #1128052
12/05/11 05:30 PM
12/05/11 05:30 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Did you install them right?
Re: Unstable at speeds [Re: Montclaire] #1128053
12/05/11 05:31 PM
12/05/11 05:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes I did...
Re: Unstable at speeds [Re: Challenger 1] #1128054
12/05/11 05:40 PM
12/05/11 05:40 PM
Was it acting like this before the rebuilding?. I'm assuming no & you rebuilt it cause bushings were worn out.
Re: Unstable at speeds [Re: RapidRobert] #1128055
12/05/11 07:09 PM
12/05/11 07:09 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
You should just junk that thing and get a real Mopar!!! Just kidding Mike. Sorry to hear you are having problems with the Challenger. Call me sometime, buddyyyyy!!!!!
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Unstable at speeds [Re: moparmikethree] #1128056
12/06/11 06:27 PM
12/06/11 06:27 PM
bought the car as a slant six, never drove it , started to restore it right away so I don't know if there was a problem. I doubt there was a problem before.
where the upper control arm mounts to the body, that was rotted out. Got one from a B-body and welded it in. This is why i think it is off
and why I want to get adjustable upper control arms
Re: Unstable at speeds [Re: moparmikethree] #1128057
12/07/11 01:13 AM
12/07/11 01:13 AM
What alignment settings did you end up w?
Re: Unstable at speeds [Re: moparmikethree] #1128058
12/07/11 02:06 AM
12/07/11 02:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You might want to check the toe cure in its travel..
if it goes toe out they can get real weird... specially
if it wants to rock side to side...then it starts
to dart back and forth and just gets worse
Re: Unstable at speeds [Re: MR_P_BODY] #1128059
12/07/11 02:41 AM
12/07/11 02:41 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sounds like a caster or toe problem, what was the readout? I'm assuming new leaf spring bushings & strut rod bushings and the sleeves are back in them.
Drag car should have 1/32" - 1/16" toe in, 0 camber, and as much positive caster as you can get. Put your weight in the driver's seat and raise the nose to the height it is in 3rd gear at the track, at race weight & fuel level. My Duster runs +7.0 LF and +7.2 RF caster, but it has the Jack Arnew reworked upper arms from its SS/IA days. It goes straight as a string @ 130, though you don't want to stick your wrist between the steering wheel spokes when you let the car straighten itself from full lock.
Re: Unstable at speeds [Re: topside] #1128060
12/07/11 02:57 AM
12/07/11 02:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I set up my race car with 10* caster but for my
Rampage(street/strip) I set that up with 5* caster
because of the effort on the street and I have wider
tires on the front of it... both cars are strut
front ends
Re: Unstable at speeds [Re: moparmikethree] #1128061
12/07/11 11:12 AM
12/07/11 11:12 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Well that would be an important fact to include. Get the adjustable arms and take it to a chassis shop, a good one, and have them blueprint the car. Who knows what may be up with it at this point.
Re: Unstable at speeds [Re: topside] #1128062
12/07/11 01:15 PM
12/07/11 01:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with this. My 63 is all stock suspension and I have about 0 camber and gave it as much positive caster as I could which was around 2 I believe but I would have to find my printout to know the right spec. I also have my toe very close to zero with it toed in a tad. It handles very good at 125 and I know most race cars handle better with the more caster.
But can you give us the specs that it is set at now ?? Ron
