Re: Unstable at speeds
[Re: moparmikethree]
#1128044
12/05/11 04:09 PM
12/05/11 04:09 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Who installed all those new parts? Did it do this befor? Seems to me, you might just need a good front end alignment.
I have mechanical Aptitude. I can screw up anything.
#1128046
12/05/11 04:15 PM
12/05/11 04:15 PM
bboogieart
Lost and Spaced
Sounds like you know what you are doing. I have only played with these so no expert. Sounds like your right about the tubular a arms. Good Luck.
#1128047
12/05/11 04:55 PM
12/05/11 04:55 PM
Posts: 4,848 Memphis
HemiRick
Memphis
You know about the offset controll arm bushings that Moog makes? May give the camber you need much cheaper than new arms.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
#1128048
12/05/11 04:58 PM
12/05/11 04:58 PM
Posts: 4,244 Canada
Kam*Kuda
Canada
How is the steering box?
Lift the car and see if you feel any play when you pull on the wheels? See if there is any excessive movement.
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: HemiRick]
#1128049
12/05/11 05:07 PM
12/05/11 05:07 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
This is a good fix...
[Re: Cuda340]
#1128050
12/05/11 05:24 PM
12/05/11 05:24 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
You need to:
1) Upgrade to properly rated torsion bars, if you have not done so already. (1970 you could get the 340 performance package which used 383 bars, I would copy that)
2) Buy the moog offset uppers. (You have to install them opposite the instructions though)
3) Check for bumpsteer and shim/slot/gusset the steering mount. Also I think Firm Feel is making an add-on brace for the bottom of the sector shaft on the box.
4) Is the box rebuilt? If not get a rebuilt box from Steer N Gear or Firm Feel.
5) Replace your strut rods. You do not need high dollar adjustables, just the the 30% oversized ones.
6) Pot coupler. The steering pot coupler can wear if left open and dry for extended periods. This will cause slop between the steering wheel and the actual imput on the box. Check for play and replace/repair if needed.
7) Alignment. For handling, you want +3.0 caster and -.5 camber but this is not always possible. Get as much + caster as possible while keeping negative camber.
There is also an adjustment that can be made for dead neurtal, where the box should basically be unassisted if going straight ahead, check the FSM for specs.
[Re: Challenger 1]
#1128052
12/05/11 05:30 PM
12/05/11 05:30 PM
Montclaire
Scranton, PA
The car was converted from a /6 to a 360 with aprox 450 hp. I did all of the work. Chrysler mechanic 31 years now.
When doing alignment could not get camber where it belongs. May buy the upper control arms ( tubular with adjustment) to get it right
Exactly right, invest in some Firm Feel upper control arms, they made a world of difference on my 71. My black 74 has the offset bushings, the FF upper arms made way more difference ,gave me like 5 degrees of positive caster.
Did you install them right?
[Re: Montclaire]
#1128053
12/05/11 05:31 PM
12/05/11 05:31 PM
Challenger 1
Cincinnati, Ohio
Yes I did...
[Re: Challenger 1]
#1128054
12/05/11 05:40 PM
12/05/11 05:40 PM
RapidRobert
Was it acting like this before the rebuilding?. I'm assuming no & you rebuilt it cause bushings were worn out.
#1128058
12/07/11 02:06 AM
12/07/11 02:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You might want to check the toe cure in its travel.. if it goes toe out they can get real weird... specially if it wants to rock side to side...then it starts to dart back and forth and just gets worse
[Re: topside]
#1128060
12/07/11 02:57 AM
12/07/11 02:57 AM
MR_P_BODY
I set up my race car with 10* caster but for my Rampage(street/strip) I set that up with 5* caster because of the effort on the street and I have wider tires on the front of it... both cars are strut front ends
#1128061
12/07/11 11:12 AM
12/07/11 11:12 AM
Montclaire
Scranton, PA
bought the car as a slant six, never drove it , started to restore it right away so I don't know if there was a problem. I doubt there was a problem before.
where the upper control arm mounts to the body, that was rotted out. Got one from a B-body and welded it in. This is why i think it is off and why I want to get adjustable upper control arms
Well that would be an important fact to include. Get the adjustable arms and take it to a chassis shop, a good one, and have them blueprint the car. Who knows what may be up with it at this point.
[Re: topside]
#1128062
12/07/11 01:15 PM
12/07/11 01:15 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Sounds like a caster or toe problem, what was the readout? I'm assuming new leaf spring bushings & strut rod bushings and the sleeves are back in them. Drag car should have 1/32" - 1/16" toe in, 0 camber, and as much positive caster as you can get. Put your weight in the driver's seat and raise the nose to the height it is in 3rd gear at the track, at race weight & fuel level. My Duster runs +7.0 LF and +7.2 RF caster, but it has the Jack Arnew reworked upper arms from its SS/IA days. It goes straight as a string @ 130, though you don't want to stick your wrist between the steering wheel spokes when you let the car straighten itself from full lock.
I agree with this. My 63 is all stock suspension and I have about 0 camber and gave it as much positive caster as I could which was around 2 I believe but I would have to find my printout to know the right spec. I also have my toe very close to zero with it toed in a tad. It handles very good at 125 and I know most race cars handle better with the more caster.
But can you give us the specs that it is set at now ?? Ron
