Toyo slick problem
#1127405
12/04/11 02:27 PM
12/04/11 02:27 PM
Posts: 1,212 Minn
SportF
Minn
My new race car, the ’62 Dodge Dart, was all over the track and actually scary to drive at the top end, and this is only an 1/8 mile track. Well, I thought this was because I only had 1 degree of caster. So offset bushings only got me another .5 degree. So, got some Magnum Force tube A arms (boy are they nice pieces), and dialed in 5 degrees. I could have had 8 degrees, by the way. Car still all over the track. Check the roll out on my 28X9X15 Toyo’s and I have 1.25 inch difference. Got some new tires, Hoosier’s, and car is now a pleasure to drive. So, any body got the same problem and we can trade? How is that for a long shot…….? Its hard to believe what that 1.25” out of about 90” total makes. 15 passes on those tires, but I got a heck of a deal on them at that 2 for one special…
Re: Toyo slick problem
[Re: SportF]
#1127408
12/04/11 02:55 PM
12/04/11 02:55 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Have you tried increase the air pressue in the smaller diameter tire to strectch it out to try and even out the rollout ?
76 Duster
work in progress
[Re: Edge]
#1127410
12/04/11 03:29 PM
12/04/11 03:29 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
I know of a NMRA SSO team that did testing for Toyo. Saw roll out differences like you mentioned. Also had other issues. Toyo was there to gather data and try to make a slick work like or better than the M/T 3055s. They went back to M/T after the test period.
That being said, all slicks are subject to rollout differences.
I'm Gumby dammit!
[Re: SportF]
#1127412
12/04/11 10:39 PM
12/04/11 10:39 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I understand your frustration. I spent $650 on some radial slicks from another company and had severe handling issues as well. Best thing I ever did was decide to just eat the loss, and not have to worry about the $$ or what might happen to the next owner. They went into the recycling pile with only 27 passes on them. I sleep good now.
[Re: SportF]
#1127420
12/05/11 02:55 AM
12/05/11 02:55 AM
Posts: 2,864 IN
Irun5snd8th
IN
My Goodyears come marked with the rollout for that exact reason. You need to specify when you order them that you want them measured and have a matched set sent to you.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: perfmachst]
#1127423
12/05/11 10:04 PM
12/05/11 10:04 PM
Posts: 1,212 Minn
SportF
Minn
Well, I talked to the Toyo Rep for the West Coast (I am currently in San Diego) and she said as a manufacturer, she couldn't do anything, but I should call the distributors from which I problaby bought it from. So I have a call in to them as they were probably closed when I called as it would have been after 5PM on the east coast. But then I am also thinking, why as a manufacturer can't you do something?
This over pressuring the tire to make it bigger...never heard of that before. Don't know if it is worth trying, or worth the safety factor. I am telling you guys, this was really quite a ride, and not fun. I almosted hated to drive the car to the starting line. On one of the first runs it shot to the wall right out of the hole and I backed off in less than 60 foot. And as I said, this car is not that fast.
