67 Coronet sway bar bushings??? #1127101
12/04/11 11:43 AM
12/04/11 11:43 AM
Pittsfield, Mass.
Russ_Davis Offline OP
Pittsfield, Mass.
How is the best way to change the front bushings??? Why do they make it so hard
Re: 67 Coronet sway bar bushings??? [Re: Russ_Davis] #1127102
12/04/11 11:59 AM
12/04/11 11:59 AM
Gateway to the West.
hemi_harvester Offline
Sway bar bushings or...strut rod bushings ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: 67 Coronet sway bar bushings??? [Re: hemi_harvester] #1127103
12/04/11 05:09 PM
12/04/11 05:09 PM
Pittsfield, Mass.
Pittsfield, Mass.
Sway bar bushings..
Re: 67 Coronet sway bar bushings??? [Re: Russ_Davis] #1127104
12/04/11 06:05 PM
12/04/11 06:05 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I am going through this with a 68 Chrysler. Not sure if they are similar but I was told some unbolted others were spot welded just drill out the spot weld and replace with a grade 8 bolt of the appropriate size.
I have mechanical Aptitude.
I can screw up anything.
Re: 67 Coronet sway bar bushings??? [Re: bboogieart] #1127105
12/04/11 06:22 PM
12/04/11 06:22 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Clean the bar and brackets real good after getting the old rubber bushing out. Slide the bracket on the bar without the bushing in the correct orientation. Lube up the bushing real good and work it onto the bar. Lube up the outside of the bushing and use a pair of channel locks with a little duct tape on them to get them into the bracket. Start at one corner and work your way up. Sometimes 2 pair of channel locks are needed. It will pop in.
Re: 67 Coronet sway bar bushings??? [Re: T2R9] #1127106
12/04/11 07:03 PM
12/04/11 07:03 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
What lots of people do, and i am one of them, is to cut away the weld portion on one end of the strap of the mount bracket.
Bend back the strap a little bit, and install the new bushing.
Weld the strap back down onto the bracket.
Of course if you go that repair method, your going to need a welder, and or die grinder, or Dremel to cut back on the weld seam.
But it's a good way to get the job done.
I never had any luck lubing up the bushing, and trying to squash the bushing in with channel locks.
Too frustrating for me, and never worked.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 67 Coronet sway bar bushings??? [Re: hemi71x] #1127107
12/04/11 07:15 PM
12/04/11 07:15 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
So does that mean there is no spot weld. Seemed an easy way out for me. Drill the weld replace with a bolt.
Re: 67 Coronet sway bar bushings??? [Re: bboogieart] #1127108
12/04/11 08:30 PM
12/04/11 08:30 PM
hemi71x Offline
hemi71x  Offline
I don't know about your 68 Chrysler.
The OP is inquiring about his 67 Coronet.
Those sway bar bushings, and mounts, would be used on the 66-69 B Body cars, and also the 67-72 A Body sway bar bushings, and mounts, would be close to being the same.
Re: 67 Coronet sway bar bushings??? [Re: bboogieart] #1127109
12/04/11 10:29 PM
12/04/11 10:29 PM
Pittsfield, Mass.
Pittsfield, Mass.
Well I went with the cut and weld. I guess thats as easy as it can be. No problems. Thanks....
Re: 67 Coronet sway bar bushings??? [Re: Russ_Davis] #1127110
12/05/11 12:08 PM
12/05/11 12:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Russ did you use a rubber bushing or a poly ? I have to do the same thing .
Re: 67 Coronet sway bar bushings??? [Re: JohnRR] #1127111
12/05/11 06:31 PM
12/05/11 06:31 PM
Pittsfield, Mass.
Pittsfield, Mass.
Went with all poly bushings.
Re: 67 Coronet sway bar bushings??? [Re: hemi71x] #1127112
12/05/11 08:16 PM
12/05/11 08:16 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I understood he asked about the 67 B body was just trying to help. I was also told to do what you said. Just seemed easier to drill out. Turns out though the spot weld was way to big. I just drilled and cut out the old rubber and it slid off the side.
Not saying your wrong just this is what I encountered, and hope it helps some one.
Neres what I have is it similar to the b-body or way off?
Re: 67 Coronet sway bar bushings??? [Re: bboogieart] #1127113
12/05/11 08:19 PM
12/05/11 08:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
the spot weld
Also looks like there wouldn't be much left once the weld were ground away(?)
Russ glad you got it figured out.
Re: 67 Coronet sway bar bushings??? [Re: bboogieart] #1127114
12/05/11 08:22 PM
12/05/11 08:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That C body mount isn't anything like the B body mount.
The B body mount is a V shaped mount with a tab on each side (sort of like this -v- ) and a strap welded across the top after the triangle shaped mount is dropped in.
Re: 67 Coronet sway bar bushings??? [Re: bboogieart] #1127115
12/05/11 08:23 PM
12/05/11 08:23 PM
Pittsfield, Mass.
Pittsfield, Mass.
Thats nothing like a 67.
Re: 67 Coronet sway bar bushings??? [Re: Russ_Davis] #1127116
12/05/11 08:25 PM
12/05/11 08:25 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Just trying to help. The procedure sure seems the same.
