Re: 67 Coronet sway bar bushings???
[Re: Russ_Davis]
#1127102
12/04/11 11:59 AM
12/04/11 11:59 AM
Posts: 3,449 Gateway to the West.
hemi_harvester
Sway bar bushings or...strut rod bushings ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
[Re: Russ_Davis]
#1127104
12/04/11 06:05 PM
12/04/11 06:05 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I am going through this with a 68 Chrysler. Not sure if they are similar but I was told some unbolted others were spot welded just drill out the spot weld and replace with a grade 8 bolt of the appropriate size.
I have mechanical Aptitude. I can screw up anything.
[Re: T2R9]
#1127106
12/04/11 07:03 PM
12/04/11 07:03 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
What lots of people do, and i am one of them, is to cut away the weld portion on one end of the strap of the mount bracket. Bend back the strap a little bit, and install the new bushing. Weld the strap back down onto the bracket. Of course if you go that repair method, your going to need a welder, and or die grinder, or Dremel to cut back on the weld seam. But it's a good way to get the job done. I never had any luck lubing up the bushing, and trying to squash the bushing in with channel locks. Too frustrating for me, and never worked.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#1127107
12/04/11 07:15 PM
12/04/11 07:15 PM
bboogieart
Lost and Spaced
So does that mean there is no spot weld. Seemed an easy way out for me. Drill the weld replace with a bolt.
[Re: bboogieart]
#1127108
12/04/11 08:30 PM
12/04/11 08:30 PM
hemi71x
I don't know about your 68 Chrysler. The OP is inquiring about his 67 Coronet. Those sway bar bushings, and mounts, would be used on the 66-69 B Body cars, and also the 67-72 A Body sway bar bushings, and mounts, would be close to being the same.
[Re: Russ_Davis]
#1127110
12/05/11 12:08 PM
12/05/11 12:08 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Well I went with the cut and weld. I guess thats as easy as it can be. No problems. Thanks....
Russ did you use a rubber bushing or a poly ? I have to do the same thing .
[Re: bboogieart]
#1127113
12/05/11 08:19 PM
12/05/11 08:19 PM
bboogieart
Lost and Spaced
the spot weld Also looks like there wouldn't be much left once the weld were ground away(?) Russ glad you got it figured out.
[Re: bboogieart]
#1127114
12/05/11 08:22 PM
12/05/11 08:22 PM
JohnRR
U.S.S.A.
I understood he asked about the 67 B body was just trying to help. I was also told to do what you said. Just seemed easier to drill out. Turns out though the spot weld was way to big. I just drilled and cut out the old rubber and it slid off the side. Not saying your wrong just this is what I encountered, and hope it helps some one. Neres what I have is it similar to the b-body or way off?
That C body mount isn't anything like the B body mount.
The B body mount is a V shaped mount with a tab on each side (sort of like this -v- ) and a strap welded across the top after the triangle shaped mount is dropped in.
[Re: Russ_Davis]
#1127116
12/05/11 08:25 PM
12/05/11 08:25 PM
bboogieart
Lost and Spaced
Just trying to help. The procedure sure seems the same.
