What Head? #1125779
12/02/11 12:22 AM
12/02/11 12:22 AM
Newark,Ohio
kissmyaspen Offline OP
Newark,Ohio
Okay, looking to run 10.90 in a 3600lb 67 satellite. what head would you go with. looking to stay with hydralic cam and stock style hd valve train. been looking at 440 source heads, edelbrocks and just looked at indy's 440 ez head. what would be the better bang for the buck.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: What Head? [Re: kissmyaspen] #1125780
12/02/11 09:13 AM
12/02/11 09:13 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
How many cubes...
Re: What Head? [Re: Dragula] #1125781
12/02/11 09:32 AM
12/02/11 09:32 AM
Newark,Ohio
Newark,Ohio
440 non stroker.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: What Head? [Re: kissmyaspen] #1125782
12/02/11 09:54 AM
12/02/11 09:54 AM
an8sec70cuda Offline
Indy EZ.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What Head? [Re: an8sec70cuda] #1125783
12/02/11 10:12 AM
12/02/11 10:12 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I don't think a Stealth or Eddie RPM will get you there unported. I ran 10.70's with unported RPM's, a 555/570 Hughes Hyd. cam, Isky 1.5 ductile iron rockers on a TRW piston 440 in a 2950lb. car with a glide.
Same combo went 10.0's with a 640 ultradyne solid and Ross pistons.
I'd have to seriously look at the cost of CNC ported Stealths or Eddie RPMs versus off the shelf Indy EZ or SRs if I were starting from scratch.
If the port volume gets too big, it will want more rpm on a 440 than a hyd. cam will handle.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: What Head? [Re: MoparBilly] #1125784
12/02/11 11:31 AM
12/02/11 11:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought my Indy EZ heads from Dwayne Porter. He did a little porting and gave me a very good price. My 63 goes 3700 with me in it and only has 7 track passes so far with a best of 10.70's so far. It is a pump gas street car raced thru the pipes. Ron
Re: What Head? [Re: an8sec70cuda] #1125785
12/02/11 11:48 AM
12/02/11 11:48 AM
Dragula Offline
Dragula  Offline
Indy EZ.
Ported Indy EZ heads, and probably a solid cam at that weight. If you also kill it by having a convertor tighter than 4000, you will need more cubes too.
Re: What Head? [Re: kissmyaspen] #1125786
12/02/11 11:51 AM
12/02/11 11:51 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Why not a Victor head? Man are they a good head for the money! They beat the 440-1 everywhere on our flow bench...
-Kenny
Re: What Head? [Re: MoparBilly] #1125787
12/02/11 11:58 AM
12/02/11 11:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
pretty sure my buddy's old 69 Coronet went 10.90's w/ e-heads, 590 cam. and 4.56's. Nothing really fancy about the car, even ran the 318 leaf springs and traction bars.
Coming soon!!!!
Re: What Head? [Re: StrokerAspen] #1125788
12/02/11 02:01 PM
12/02/11 02:01 PM
Newark,Ohio
Newark,Ohio
-Kenny
I looked at them too. i kinda know 10.90's is stretch for this set-up.. guess i really just want to be faster than 11.50 because i want to run nss 11.50 or 11 class. its been 11.80's with just a 509 mp cam stock 906 heads flat top pistons.. nothing fancy at all and 1.58 60'.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: What Head? [Re: kissmyaspen] #1125789
12/02/11 02:21 PM
12/02/11 02:21 PM
Dragula Offline
Dragula  Offline
-Kenny
You have a decent 60ft, so heads will help your ET for sure, and so would a solid cam. I would suggest the Mopar .557 solid and a good set of mildly ported heads. We put a 512 togather on pump gas with unported EZ heads, and it is a beast. I like them, and the valves are a 2.19" on the intake side which really seems to get the things breathing. I am not a fan of eddy heads. If your going to spend the money, get a head you can come back to later and fully port them to match your next combo. Your going to need about 90hp to hit your goal of 10's so, get a good set, maybe a used set that just needs a going thru to be put back into action.
Re: What Head? [Re: kissmyaspen] #1125790
12/02/11 02:24 PM
12/02/11 02:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
-Kenny
Don't some NSS rules limit head choice? I'd think a home ported set of Stealth heads 590-600 soild lift cam and a set of roller rockers should get you close to 10.90 as long as your convert and gear are matched up.
Re: What Head? [Re: Dragula] #1125791
12/02/11 02:26 PM
12/02/11 02:26 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
i thinkn stealths with bowl blending, port matching and a good valve job and a nice solid cam like the MP .557 nad a performer RPM intake manifold and nice headers will get you what you want. Or at least real close.
If you were to stroke it to 500 inches or more, you would definetly get what you want.
Re: What Head? [Re: domingo] #1125792
12/02/11 04:01 PM
12/02/11 04:01 PM
Alberta Canada
Alberta Canada
HAHA! Sorry, just realized you are shooting for 10.90. I read it as 10.00 at first. I was thinking "Man, 10.00 with RPM's might be a strech"
10.90 should be able to be done with the RPM's or Stealths, I wouls still go to a victor if it is allowed.
-Kenny
Re: What Head? [Re: MoparBilly] #1125793
12/02/11 04:08 PM
12/02/11 04:08 PM
ill
dennismopar73 Offline
ill
BU;; SHZZZ
Re: What Head? [Re: dennismopar73] #1125794
12/02/11 10:11 PM
12/02/11 10:11 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
BU;; SHZZZ
Care to elaborate with intelligent conversation?? I'm simply relating personal real-world info. You care to engage us with your brilliance, or is this just a drive by from the peanut gallery??
Mr. Yuck,
You mentioned a 10.90 Eddie combo that featured a solid cam, the OP said he prefered to stay hydraulic.
Everyone seems quick to bash suggestions without reading all the info.
The Victors require an offset rocker, correct? That adds an expense as well.
Re: What Head? [Re: MoparBilly] #1125795
12/02/11 10:19 PM
12/02/11 10:19 PM
okla.
sam64 Online content
sam64  Online Content
okla.
beleive me them gebharts[moparbilly and family]have tried more real world combo's than andy f.
Re: What Head? [Re: sam64] #1125796
12/02/11 10:59 PM
12/02/11 10:59 PM
Newark,Ohio
Newark,Ohio
Thats one reason I kinda shyed away from the victors plus the seats need finished.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: What Head? [Re: kissmyaspen] #1125797
12/05/11 01:53 PM
12/05/11 01:53 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Mine has lil ez 295's from Compu-flow. 10.20's all day long @ 3780 through the mufflers on pump gas. Then drive to the Sonic for a burger
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: What Head? [Re: 67HEMI] #1125798
12/05/11 02:31 PM
12/05/11 02:31 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Big hydraulic,Ported EZ heads, or Victors if you can stretch that far, should sneak you into the 10's, if you already have a decent converter.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
