Re: What Head?
[Re: kissmyaspen]
#1125782
12/02/11 09:54 AM
12/02/11 09:54 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Re: What Head?
[Re: an8sec70cuda]
#1125783
12/02/11 10:12 AM
12/02/11 10:12 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I don't think a Stealth or Eddie RPM will get you there unported. I ran 10.70's with unported RPM's, a 555/570 Hughes Hyd. cam, Isky 1.5 ductile iron rockers on a TRW piston 440 in a 2950lb. car with a glide. Same combo went 10.0's with a 640 ultradyne solid and Ross pistons.
I'd have to seriously look at the cost of CNC ported Stealths or Eddie RPMs versus off the shelf Indy EZ or SRs if I were starting from scratch. If the port volume gets too big, it will want more rpm on a 440 than a hyd. cam will handle.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
Re: What Head?
[Re: MoparBilly]
#1125787
12/02/11 11:58 AM
12/02/11 11:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
pretty sure my buddy's old 69 Coronet went 10.90's w/ e-heads, 590 cam. and 4.56's. Nothing really fancy about the car, even ran the 318 leaf springs and traction bars.
Re: What Head?
[Re: kissmyaspen]
#1125789
12/02/11 02:21 PM
12/02/11 02:21 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
Why not a Victor head? Man are they a good head for the money! They beat the 440-1 everywhere on our flow bench...
-Kenny
I looked at them too. i kinda know 10.90's is stretch for this set-up.. guess i really just want to be faster than 11.50 because i want to run nss 11.50 or 11 class. its been 11.80's with just a 509 mp cam stock 906 heads flat top pistons.. nothing fancy at all and 1.58 60'.
You have a decent 60ft, so heads will help your ET for sure, and so would a solid cam. I would suggest the Mopar .557 solid and a good set of mildly ported heads. We put a 512 togather on pump gas with unported EZ heads, and it is a beast. I like them, and the valves are a 2.19" on the intake side which really seems to get the things breathing. I am not a fan of eddy heads. If your going to spend the money, get a head you can come back to later and fully port them to match your next combo. Your going to need about 90hp to hit your goal of 10's so, get a good set, maybe a used set that just needs a going thru to be put back into action.
Re: What Head?
[Re: kissmyaspen]
#1125790
12/02/11 02:24 PM
12/02/11 02:24 PM
Mr.Yuck
Brookeville, Md
-Kenny
Don't some NSS rules limit head choice? I'd think a home ported set of Stealth heads 590-600 soild lift cam and a set of roller rockers should get you close to 10.90 as long as your convert and gear are matched up.
Re: What Head?
[Re: MoparBilly]
#1125793
12/02/11 04:08 PM
12/02/11 04:08 PM
Posts: 2,177 ill
dennismopar73
ill
BU;; SHZZZ
Re: What Head?
[Re: dennismopar73]
#1125794
12/02/11 10:11 PM
12/02/11 10:11 PM
MoparBilly
Phoenix, AZ
BU;; SHZZZ
Care to elaborate with intelligent conversation?? I'm simply relating personal real-world info. You care to engage us with your brilliance, or is this just a drive by from the peanut gallery??
Mr. Yuck, You mentioned a 10.90 Eddie combo that featured a solid cam, the OP said he prefered to stay hydraulic.
Everyone seems quick to bash suggestions without reading all the info.
The Victors require an offset rocker, correct? That adds an expense as well.
Re: What Head?
[Re: sam64]
#1125796
12/02/11 10:59 PM
12/02/11 10:59 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
Thats one reason I kinda shyed away from the victors plus the seats need finished.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
Re: What Head?
[Re: 67HEMI]
#1125798
12/05/11 02:31 PM
12/05/11 02:31 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Big hydraulic,Ported EZ heads, or Victors if you can stretch that far, should sneak you into the 10's, if you already have a decent converter. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
