Driveshaft angle
#1122298
11/27/11 11:33 AM
11/27/11 11:33 AM
Posts: 369 Chicago
curbman68
Chicago
How much, if any, side to side driveshaft angle at the transmission is normal or acceptable? Installed a modified K member on a 65 B body and it seems to me like the engine does not sit as straight as it should, trans tailshaft does not point directly at the real axle yoke. I know the engine is supposed to be offset side to side, don't think that is the problem. Unfortunately I never looked at the driveshaft angle before swapping out the original K member.
Re: Driveshaft angle
[Re: curbman68]
#1122299
11/27/11 04:23 PM
11/27/11 04:23 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
What u-joint angles does it have at the front and rear? Side view and top view?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1122300
11/27/11 11:24 PM
11/27/11 11:24 PM
Posts: 369 Chicago
curbman68
Chicago
Have taken it back apart, going to relocate the K-member mounts to better suit my needs. Should be able to get it all straight that way.
[Re: savoy64]
#1122303
11/28/11 12:13 AM
11/28/11 12:13 AM
Posts: 1,607 Western Washington
Sixgun
Western Washington
far as I know, very little side to side or none?
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
