Driveshaft angle #1122298
11/27/11 11:33 AM
11/27/11 11:33 AM
Chicago
curbman68 Offline OP
Chicago
How much, if any, side to side driveshaft angle at the transmission is normal or acceptable? Installed a modified K member on a 65 B body and it seems to me like the engine does not sit as straight as it should, trans tailshaft does not point directly at the real axle yoke. I know the engine is supposed to be offset side to side, don't think that is the problem. Unfortunately I never looked at the driveshaft angle before swapping out the original K member.
Re: Driveshaft angle [Re: curbman68] #1122299
11/27/11 04:23 PM
11/27/11 04:23 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What u-joint angles does it have at the front and rear? Side view and top view?
Re: Driveshaft angle [Re: jbc426] #1122300
11/27/11 11:24 PM
11/27/11 11:24 PM
Chicago
Chicago
Have taken it back apart, going to relocate the K-member mounts to better suit my needs. Should be able to get it all straight that way.
Re: Driveshaft angle [Re: curbman68] #1122301
11/28/11 12:02 AM
11/28/11 12:02 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The mopar performance chassis manual has alot of good info about the drivetrain angles and their relationships to each other...It's a good book to have when setting up a vehicle...
Re: Driveshaft angle [Re: screamindriver] #1122302
11/28/11 12:10 AM
11/28/11 12:10 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
you may have a hard time straightening it up because the trans/driveshaft tunnel isnt straight either----while you have it inplace take a look at the clearances in relation to the tunnel----bob
Re: Driveshaft angle [Re: savoy64] #1122303
11/28/11 12:13 AM
11/28/11 12:13 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
far as I know, very little side to side or none?
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: Driveshaft angle [Re: curbman68] #1122304
11/28/11 04:34 AM
11/28/11 04:34 AM
Cab_Burge Online work
Cab_Burge  Online Work
Your way better off havig some angle, both up and down and side to side thatn having the driveshaft perfecftly aligned , The Ujoints need to change angles as they rotate to make the needle bearings inside roll on the Ujoint pins, if they do't they will brenell(SP) and die
Re: Driveshaft angle [Re: Cab_Burge] #1122305
11/28/11 07:54 PM
11/28/11 07:54 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the transmission cannot point directly at the rear end yoke because you will get an awful harmonic vibration and your needle bearings will die as stated before----all our old muscle cars have the front of engine offset to the right to allow for the steering gear---the radiator is even offset to be in the middle of the fan----the battery is on the left because there is room there----the trans/driveshaft tunnel angles from the right (front) to the left (rear)----bob
