motor locked up ? what caused it?
#1122058
11/26/11 08:37 PM
11/26/11 08:37 PM
Posts: 1,411 northeast ohio
hulmule
northeast ohio
Bought a 99 Dakota with a 3.9 v6. clean little truck, but it needs a motor.now my question is the guy said it locked up going down the road. no holes in the block, but you aint moving the crank--tried with a bar. So what would have done this?havent pulled it yet, may just sell like it is, dont have time.unless someone feels its a easy job and possible easy fix in the motor.So what do you think guys?
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: motor locked up ? what caused it?
[Re: hulmule]
#1122061
11/26/11 08:43 PM
11/26/11 08:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Spun bearings... due to lack of oil
[Re: MR_P_BODY]
#1122062
11/26/11 08:51 PM
11/26/11 08:51 PM
hulmule
northeast ohio
radiator is still full of coolant. mains and rod bearings?? pull the pan and take a look?
[Re: hulmule]
#1122063
11/26/11 10:27 PM
11/26/11 10:27 PM
Posts: 30,447 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
as said above ...probably out of oil ...
Re: motor locked up ? what cuased it?
[Re: buildanother]
#1122065
11/27/11 02:17 AM
11/27/11 02:17 AM
DaytonaTurbo
Manitoba, Canada
PLugged pickup screen is common.
Pickup probably clogged with sludge and starved the oil pump. My parents bought a used 96 dak with the 3.9 and it did the same thing. My dad shut it down when the lifters bled down on the highway and started clacking away. Had to pull the pan, remove the pickup and clean everything out. Pulled the valve covers and they were full of sludge too.
[Re: dogdays]
#1122069
11/27/11 04:06 PM
11/27/11 04:06 PM
MR_P_BODY
Rod bearing. Easy fix, usually. R.
Other than having the crank turned
[Re: MR_P_BODY]
#1122071
11/30/11 03:06 PM
11/30/11 03:06 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Knock the high spots off and toss in a new bearing ....
