motor locked up ? what caused it? #1122058
11/26/11 08:37 PM
11/26/11 08:37 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Bought a 99 Dakota with a 3.9 v6. clean little truck, but it needs a motor.now my question is the guy said it locked up going down the road. no holes in the block, but you aint moving the crank--tried with a bar. So what would have done this?havent pulled it yet, may just sell like it is, dont have time.unless someone feels its a easy job and possible easy fix in the motor.So what do you think guys?
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: motor locked up ? what cuased it? [Re: hulmule] #1122059
11/26/11 08:38 PM
11/26/11 08:38 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
PLugged pickup screen is common.
Re: motor locked up ? what caused it? [Re: hulmule] #1122060
11/26/11 08:39 PM
11/26/11 08:39 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Severe loss of coolant ? ... maybe the bores are full of it. PULL all the plugs then try barring it over.
Re: motor locked up ? what caused it? [Re: hulmule] #1122061
11/26/11 08:43 PM
11/26/11 08:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Spun bearings... due to lack of oil
Re: motor locked up ? what caused it? [Re: MR_P_BODY] #1122062
11/26/11 08:51 PM
11/26/11 08:51 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
radiator is still full of coolant. mains and rod bearings?? pull the pan and take a look?
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: motor locked up ? what caused it? [Re: hulmule] #1122063
11/26/11 10:27 PM
11/26/11 10:27 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
as said above ...probably out of oil ...
Re: motor locked up ? what caused it? [Re: dOoC] #1122064
11/27/11 12:53 AM
11/27/11 12:53 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Pull the pan or heads and find out.........
Re: motor locked up ? what cuased it? [Re: buildanother] #1122065
11/27/11 02:17 AM
11/27/11 02:17 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Pickup probably clogged with sludge and starved the oil pump. My parents bought a used 96 dak with the 3.9 and it did the same thing. My dad shut it down when the lifters bled down on the highway and started clacking away. Had to pull the pan, remove the pickup and clean everything out. Pulled the valve covers and they were full of sludge too.
Re: motor locked up ? what caused it? [Re: hulmule] #1122066
11/27/11 02:48 AM
11/27/11 02:48 AM
had a moderately severe tapping in a /6, assumed it was a TC bolt loose as I had that before. Several days of driving later it just locked solid going down the road. I'm assuming it was a rod bearing & it finally threw it
Re: motor locked up ? what caused it? [Re: MR_P_BODY] #1122067
11/27/11 03:56 AM
11/27/11 03:56 AM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
with Mike on this..most likely
just drove the hell out of it and hardly
(if ever) changed/re-filled the oil.
Plymouth Makes It!
Re: motor locked up ? what caused it? [Re: RoadRunnerLuva] #1122068
11/27/11 05:58 AM
11/27/11 05:58 AM
dogdays Offline
dogdays  Offline
Rod bearing. Easy fix, usually.
R.
Re: motor locked up ? what caused it? [Re: dogdays] #1122069
11/27/11 04:06 PM
11/27/11 04:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R.
Other than having the crank turned
Re: motor locked up ? what caused it? [Re: MR_P_BODY] #1122070
11/30/11 03:04 PM
11/30/11 03:04 PM
dogdays Offline
dogdays  Offline
That's not hard in my book, because someone else does it!
R.
Re: motor locked up ? what caused it? [Re: MR_P_BODY] #1122071
11/30/11 03:06 PM
11/30/11 03:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
R.
Knock the high spots off and toss in a new bearing ....
