Valve seal replacement... #1119660
11/23/11 10:08 AM
11/23/11 10:08 AM
tboomer Offline OP
tboomer  Offline OP
How big of a pain is it to replace valve seals on cylinder heads without taking them off? It really isn't cost effective to do anything more to my current heads and money is gonna get a little tight so new ones are out of the question. I also will have the springs checked out and run the pooch as it is for next year...Thanks!! Ted
Re: Valve seal replacement... [Re: tboomer] #1119661
11/23/11 10:14 AM
11/23/11 10:14 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Piece of cake Ted, if your pulling the springs to check, the seals take 10 seconds to pop off and put new ones on...you'll be fine...
RIP Monte Smith
Re: Valve seal replacement... [Re: CompWedgeEngines] #1119662
11/23/11 10:21 AM
11/23/11 10:21 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,Todd! Have a great turkey day tommorow!!
Re: Valve seal replacement... [Re: tboomer] #1119663
11/23/11 10:30 AM
11/23/11 10:30 AM
Guitar Jones Offline
I bought the $50 Mancini tool and it works fine, you can't take all the springs off at once though, you'll have no way to keep the valves from dropping into the cylinder. I use a cheap compression gauge hose with the valve core removed to put compressed air in the cylinder. You can only do one cylinder at a time that way though.
Re: Valve seal replacement... [Re: tboomer] #1119664
11/23/11 10:33 AM
11/23/11 10:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ted with this tool it is a piece of cake ! I bought this from Mancini when I built my 493 as I broke the cam in on the outer springs so I used this to put the inner springs back in on the car. It makes the job so easy as this is the best valve spring tool for doing them on the car I have ever used. I would gladly lend it to you but you may have a slight drive to pick it up. I like it because you bolt it on with the rocker shaft hold down bolts and then you screw the allen screw down until you are ready to remove the keepers. And you can use both hands to remove the keepers as you dont have the other hand holding and pushing a tool down. It works great. Ron
Re: Valve seal replacement... [Re: 383man] #1119665
11/23/11 10:35 AM
11/23/11 10:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a side pic. Ron
Re: Valve seal replacement... [Re: 383man] #1119666
11/23/11 10:41 AM
11/23/11 10:41 AM
That tool is really the cats behind, I just didn't want to spend $200 on a tool that wouldn't be used that often but it is pretty neat.
Re: Valve seal replacement... [Re: Guitar Jones] #1119667
11/23/11 10:45 AM
11/23/11 10:45 AM
tboomer Offline OP
tboomer  Offline OP
Thanks for the detailed pics,Ron!! I agree with the guitar guy,too...200.00 is a lot to spend on a tool that may only be used once..I hope Lonemopar or bad1970dust has one..Those guys have everything and know thier stuff!
Re: Valve seal replacement... [Re: tboomer] #1119668
11/23/11 10:51 AM
11/23/11 10:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I did not think I spent that much but I bought it with a bunch of other parts and do not know the real price I paid. But it was worth it to me as I will use it many more times. Ron
Re: Valve seal replacement... [Re: 383man] #1119669
11/23/11 11:00 AM
11/23/11 11:00 AM
tboomer Offline OP
tboomer  Offline OP
But you probably do repair jobs on the side for other guys..I can see wht you need one!
Re: Valve seal replacement... [Re: tboomer] #1119670
11/23/11 11:11 AM
11/23/11 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Think of it this way Ted... what does a set of head
gaskets cost you and if you dont have a off engine
spring compressor you would need to buy it too OR
take them to a shop which cost
Re: Valve seal replacement... [Re: MR_P_BODY] #1119671
11/23/11 11:16 AM
11/23/11 11:16 AM
tboomer Offline OP
tboomer  Offline OP
Point taken,Raff! But I am not going to race much next year..I have revived one of my old hobbies that is almost as much fun. I tell ya...It is a good thing the stores sell frozen turkeys....I struck out!!
Re: Valve seal replacement... [Re: tboomer] #1119672
11/23/11 11:34 AM
11/23/11 11:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I seen about 40 turkeys on my property when I was
bow hunting... the wife got one in the spring hunt
Re: Valve seal replacement... [Re: tboomer] #1119673
11/23/11 11:36 AM
11/23/11 11:36 AM
There is always USPS flat rate boxes...It wouldn't cost much to ship it back and forth. Just sayin'.
Re: Valve seal replacement... [Re: Guitar Jones] #1119674
11/23/11 03:23 PM
11/23/11 03:23 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I use a 12pt socket deepwell.
Mopar Performance
Re: Valve seal replacement... [Re: moparniac] #1119675
11/23/11 03:49 PM
11/23/11 03:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ted if you pay shipping (I would but I am broke right now) I will ship it to you. You can use it and take as long as you like. Then ship it back when done. I have no problem with that if you wanted to do it. Ron
Re: Valve seal replacement... [Re: tboomer] #1119676
11/23/11 05:31 PM
11/23/11 05:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ted I have one of the old MP ones Mancini sold back in the day. Works fine for stock type shaft set ups. If you want I can send it to you just send me your mailing address.
Re: Valve seal replacement... [Re: Al_Alguire] #1119677
11/23/11 08:50 PM
11/23/11 08:50 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
ok, I'll bite. I thought this thing went together last winter and you have one season on it??? Why do you need to change valve seals?? I would be taking names and kickin you know what. I would send you my PowerHouse tool, but it is for little block.
Re: Valve seal replacement... [Re: weedlayer] #1119678
11/24/11 12:06 PM
11/24/11 12:06 PM
tboomer Offline OP
tboomer  Offline OP
Thanks,Ron! Mighty kind of you..Al,I may take you up on that..Here's to both you guys! Ray...The engine has been together for two years so it is possible that there was a seal failure..No ones fault,things do happen! Last year Jim did the suspension and tranny..
Re: Valve seal replacement... [Re: tboomer] #1119679
11/24/11 12:25 PM
11/24/11 12:25 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
