Re: Valve seal replacement...
[Re: tboomer]
#1119661
11/23/11 10:14 AM
11/23/11 10:14 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Piece of cake Ted, if your pulling the springs to check, the seals take 10 seconds to pop off and put new ones on...you'll be fine...
RIP Monte Smith
[Re: tboomer]
#1119663
11/23/11 10:30 AM
11/23/11 10:30 AM
Guitar Jones
I bought the $50 Mancini tool and it works fine, you can't take all the springs off at once though, you'll have no way to keep the valves from dropping into the cylinder. I use a cheap compression gauge hose with the valve core removed to put compressed air in the cylinder. You can only do one cylinder at a time that way though.
[Re: 383man]
#1119666
11/23/11 10:41 AM
11/23/11 10:41 AM
Guitar Jones
That tool is really the cats behind, I just didn't want to spend $200 on a tool that wouldn't be used that often but it is pretty neat.
[Re: tboomer]
#1119670
11/23/11 11:11 AM
11/23/11 11:11 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks for the detailed pics,Ron!! I agree with the guitar guy,too...200.00 is a lot to spend on a tool that may only be used once..I hope Lonemopar or bad1970dust has one..Those guys have everything and know thier stuff!
Think of it this way Ted... what does a set of head gaskets cost you and if you dont have a off engine spring compressor you would need to buy it too OR take them to a shop which cost
[Re: tboomer]
#1119672
11/23/11 11:34 AM
11/23/11 11:34 AM
MR_P_BODY
Point taken,Raff! But I am not going to race much next year..I have revived one of my old hobbies that is almost as much fun. I tell ya...It is a good thing the stores sell frozen turkeys....I struck out!!
I seen about 40 turkeys on my property when I was bow hunting... the wife got one in the spring hunt
[Re: tboomer]
#1119673
11/23/11 11:36 AM
11/23/11 11:36 AM
Guitar Jones
There is always USPS flat rate boxes...It wouldn't cost much to ship it back and forth. Just sayin'.
[Re: Guitar Jones]
#1119674
11/23/11 03:23 PM
11/23/11 03:23 PM
Posts: 6,295 U.S.
moparniac
U.S.
I use a 12pt socket deepwell.
Mopar Performance
[Re: tboomer]
#1119676
11/23/11 05:31 PM
11/23/11 05:31 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Ted I have one of the old MP ones Mancini sold back in the day. Works fine for stock type shaft set ups. If you want I can send it to you just send me your mailing address.
