Re: Standard port victor's on a 431?
[Re: Darrin Burt]
#1115327
11/17/11 06:08 AM
11/17/11 06:08 AM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
What does Edelbrock have to say? From the specs they look to be an excellent head for a race application with less than 500 cubes. Looks to me like they will work, but will want some rpm as torque peak may come in about 4800 rpm.
[Re: Darrin Burt]
#1115329
11/17/11 02:23 PM
11/17/11 02:23 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
What do you guys think of running standard port victors on a street/strip 431 motor? Car is a 4 speed with 4.10's 3700 lbs.
Are these heads a waste of time, or would they be a good choice?
Everything else on the engine is out for debate, but it has to be a 431.
Thanks!
Hands down, an AWESOME HEAD. They out flowed 440-1's everywhere on our bench. Same guy ported both heads.
-Kenny
[Re: StrokerAspen]
#1115330
11/17/11 02:36 PM
11/17/11 02:36 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
You won't be disappointed! We're getting ready to do a series of BB builds for CC starting with a steel crank 400 and stealth/victor heads then going to a stroker and comparing those heads with the MW Victor and then a highend build possibly with a Koleno Block.
Std. port Victors IMO are an awesome head but require alot of pushrod clearancing. Only downfall. And they really respond to a good valve job/chamber cut. Brian
Brian Hafliger
[Re: Brian Hafliger]
#1115331
11/17/11 04:18 PM
11/17/11 04:18 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Brian How can a head that flows as much as the Victor, not push the rpm up on a smaller none stroked motor. People refer to their suitability to small engines almost in the same vein as the RPM'S, which are more of a stock replacement. Is it because they have a broader spread of power and better low to midrange flow numbers. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1115332
11/17/11 04:35 PM
11/17/11 04:35 PM
gregsdart
I am curious too. I am willing to bet the reason they flow that well and can work with a smaller motor is the valve length, which allows a small port to flow so well. Same CSA, but a MUCH better port.
#1115334
11/17/11 08:15 PM
11/17/11 08:15 PM
deaks
robin hood country
My original thoughts were to maybe step up to the EZ's next but the more i hear about the Victors the better they sound. Mick
[Re: Darrin Burt]
#1115338
11/18/11 09:58 AM
11/18/11 09:58 AM
Posts: 151 N.E. Ohio
OhioGTX
N.E. Ohio
I have been running the std port victors on my 499 for the past 2 years. For the money they are a great deal; Performance has been as expected and the only drawback is the work required to clear the push rods. I think I spent about 3 hours with a grinder to get them where I needed them. The benefit I do not hear much about, but was really good for me is Header fitment. I am running Hooker 2" headers in a B body and the fitment was better with these heads than stock steel heads. Only 1 place I had to modify and that was done with a small pipe, block of wood and 2lb hammer.
Best performance with the heads noted in my sig...
68 GTX, 9.38 at 144, Best Machine 540..
[Re: OhioGTX]
#1115339
11/18/11 10:44 AM
11/18/11 10:44 AM
deaks
robin hood country
Are you still running the R280 ? Mick
[Re: deaks]
#1115340
11/18/11 10:51 AM
11/18/11 10:51 AM
OhioGTX
N.E. Ohio
Mick - yes still running a 30 year old camshaft ( literally)..it is the crane R280/670 with a set of k-motion springs..The cam is ok, but others would be faster I am sure..
[Re: dragram440]
#1115343
11/18/11 01:12 PM
11/18/11 01:12 PM
deaks
robin hood country
It will be interesting to see how your car performs with the new heads, as the motor is not a million miles from mine, although your stage 6's have the raised exhaust port unlike my edelbrocks. You can be the test bed, so to speak. ![](/ubbthreads/images/graemlins/laugh2.gif) Mick
[Re: deaks]
#1115344
11/18/11 02:41 PM
11/18/11 02:41 PM
BradH
Was this response directed to me? ![](/ubbthreads/images/graemlins/confused.gif)
