Re: stock smallblock rods...
[Re: mshred]
#1114860
11/16/11 05:06 AM
11/16/11 05:06 AM
dartman366
Mt. Vernon, Ohio
cannot tell you what they can handle, but I know they will take quite a pounding, my old 366 was testiment to that, 11-teens in a 3200# dart for 13 years, sold it 4 years ago and the guy is still running it
[Re: MoparforLife]
#1114862
11/16/11 11:20 AM
11/16/11 11:20 AM
Posts: 2,513 PA
moparacer
PA
Anyone ever seen a 340/360 rod break? I haven't....Seen some bent in a 90 degree angle and twisted like a pretzel when a crank broke, but never had one break....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: dustergirl340]
#1114865
11/16/11 01:18 PM
11/16/11 01:18 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
I know of a lot of fords, and chevys with stock mopar rods in them, Polished side beams, shot peened, and resized they can take a pounding. I screwed up once and put SIR eagle rods in a 360, and put the reworked stock rods on the shelf, I dont trust that short block now because I know the SIRs are a grenade waiting for the pin to be pulled. Yes the mopar rods could brake just as easy, but there are more shot SIRs than stock mopar rods that I personally know of.
A guy I know had a 347 ford with mopar 6.123 340 rods in it, and ran a lot of spray, and the only reason it popped is after 4 years of pounding it he decited to freshen the bottom end, and didnt check over the heads, he dropped a valve, killed a piston and corked a rod, that rod bent hit the crank and it was cut in half along with the stock ford block.
He still has that rod and piston on his shelf, looks like the rod was in a metal shear.
Kasey
[Re: Moparnut426]
#1114866
11/16/11 01:48 PM
11/16/11 01:48 PM
Guitar Jones
My old 363 has stock rods in it with ARP bolts. Been twisting it to 7200 for 15 years. Ran a best of 10.16 at 2600 pounds.
[Re: Moparnut426]
#1114869
11/16/11 07:24 PM
11/16/11 07:24 PM
They are great--If they are straight , have reg ole ARP bolts, and are machined by a good shop they are almost indestructable--and..if you have a race engine most likely you have pretty light pistons so that makes them even stronger--old TRW slugs can kill any combo but I love stock SB rods! 4 small blocks--8 years, 250-300 rounds a year, never as much as a spun bearing! SIR's have a bad rap but you have to consider that they have been through many versions--first ones had knurled bolts that were not so hot, then a batch was made with tang grooves in the wrong place, and as time went on bolt combos got better. They are easy to over torque and the bushing quality is questionable--they are light and make one turn like a chainsaw but I have had 3 engines experience failure with SIR's so I don't use them anymore. So...compare good stock rods with bolts to the H Beams out there and stockers win IMO>
[Re: Moparnut426]
#1114871
11/16/11 11:01 PM
11/16/11 11:01 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Kasey
what is the bearing size of sb ford and how did they do that sounds like alote bull sheet going around
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Moparnut426]
#1114873
11/17/11 01:44 AM
11/17/11 01:44 AM
Posts: 35 Minot, ND
darndart
Minot, ND
Kasey
I don't beleive this is possible. I've built a couple 347's with 5.4" rod and the wrist pin intersects the oil rings. A 6.123 rod would put the piston somewhere in the middle of cylinder head!
My son's 427/351windsor based stroker uses a 6.125 SBC rod. I could see the Mopar rod maybe used in that combo. But the crank still has a 2.10 SBC jouranl size!!!!
73 Dart Sport 340, 410ci, Indy 360-2 230CNC. 72 Demon 340 4-speed 01 Ram Quad Cab 89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI 86 Mustang GT 5.0 AOD 82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
[Re: darndart]
#1114874
11/17/11 12:23 PM
11/17/11 12:23 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
im running stock rods...lightened balanced polished and shot peened, ive turned the motor 8k by accident a few times a few yrs ago..but motor still runs excellent... 6.67 1/8th last time out...
i went through a bunch of rods trying to get a set of 10 all done up the same... i had 6 rods left over after doing this prep.. I had a ford guy want those so i got 2 more done to match that left over 6 rods..and sold them to him for 150 bucks..he put them in a ford stroker also...and is happy last i heard?
hold a 340 rod next to a big block chevy rod then youll get the picture..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: darndart]
#1114876
11/18/11 05:19 PM
11/18/11 05:19 PM
Moparnut426
Kasey
Might have been in his other 302 that had an offset ground crank inn it. Now that you say that. The last few 347s i built were way op in the piston also.
Kasey
[Re: mshred]
#1114878
11/19/11 12:41 AM
11/19/11 12:41 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
So is shot peening and polishing stock rods a must in a high horsepower application?
Aftermarket rods is a must in high horsepower applications. The lighter the piston, the easier it is on the rod. The shorter the stroke, the better.
