Page 1 of 3 1 2 3
stock smallblock rods... #1114859
11/16/11 01:02 AM
11/16/11 01:02 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
how much RPM and power can they take? Obviously with a good set of rod bolts installed as well and a balance job, what is the most they can handle?
Re: stock smallblock rods... [Re: mshred] #1114860
11/16/11 05:06 AM
11/16/11 05:06 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
cannot tell you what they can handle, but I know they will take quite a pounding, my old 366 was testiment to that, 11-teens in a 3200# dart for 13 years, sold it 4 years ago and the guy is still running it
Re: stock smallblock rods... [Re: dartman366] #1114861
11/16/11 10:57 AM
11/16/11 10:57 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
340/360 rods are somewhat heavier than the 318 rod but either are used in a lot of circle cars because of the rules.
yhey run well and even the lighter ones are heavier than the chevie rods.
Re: stock smallblock rods... [Re: MoparforLife] #1114862
11/16/11 11:20 AM
11/16/11 11:20 AM
PA
moparacer Offline
moparacer  Offline
PA
Anyone ever seen a 340/360 rod break? I haven't....Seen some bent in a 90 degree angle and twisted like a pretzel when a crank broke, but never had one break....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: stock smallblock rods... [Re: moparacer] #1114863
11/16/11 11:30 AM
11/16/11 11:30 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
yes they can break!!! i had a set redone about 5 yrs ago that went into a low 11 sec. 340 (shifting @ 6200)and before they were redone i asked about magna-fluxing them and machine shop owner said no they never break. guess again. after about 20 passes, mostly 1/8th mile 1s, the car developed a bad vibration so we started investigating and found #7 had snapped off. it put a divit in the bottom of that cylinder, broke that piston and bent the valves also. so i lost a block and a set of pistons because they didn't check them
Re: stock smallblock rods... [Re: mshred] #1114864
11/16/11 11:54 AM
11/16/11 11:54 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
My car has only run a best of 12.40 but it has run hundreds of passes with stock rods with heavy TRW pistons and shifted at 6,200 RPM.
Re: stock smallblock rods... [Re: dustergirl340] #1114865
11/16/11 01:18 PM
11/16/11 01:18 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I know of a lot of fords, and chevys with stock mopar rods in them, Polished side beams, shot peened, and resized they can take a pounding. I screwed up once and put SIR eagle rods in a 360, and put the reworked stock rods on the shelf, I dont trust that short block now because I know the SIRs are a grenade waiting for the pin to be pulled. Yes the mopar rods could brake just as easy, but there are more shot SIRs than stock mopar rods that I personally know of.
A guy I know had a 347 ford with mopar 6.123 340 rods in it, and ran a lot of spray, and the only reason it popped is after 4 years of pounding it he decited to freshen the bottom end, and didnt check over the heads, he dropped a valve, killed a piston and corked a rod, that rod bent hit the crank and it was cut in half along with the stock ford block.
He still has that rod and piston on his shelf, looks like the rod was in a metal shear.
Kasey
Re: stock smallblock rods... [Re: Moparnut426] #1114866
11/16/11 01:48 PM
11/16/11 01:48 PM
Guitar Jones Offline
My old 363 has stock rods in it with ARP bolts. Been twisting it to 7200 for 15 years. Ran a best of 10.16 at 2600 pounds.
Re: stock smallblock rods... [Re: Guitar Jones] #1114867
11/16/11 03:39 PM
11/16/11 03:39 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
So is shot peening and polishing stock rods a must in a high horsepower application?
Re: stock smallblock rods... [Re: mshred] #1114868
11/16/11 03:46 PM
11/16/11 03:46 PM
Moparnut426 Offline
Moparnut426  Offline
I know that when I got my Childs and alberts rods for my 408, they were shot peened from the factory, and there wasnt a sign of a stress risor anywhere on them, the King billet rods in my buddies sbc are shot peened, and they also are stress risor free.
All the polishing does is takes the rough casting marks from the sides, and also eliminates any stress risors, shot peening takes both stress risors out, and is suposed to "even out" the metallurgy in the rods also.
Kasey
Re: stock smallblock rods... [Re: Moparnut426] #1114869
11/16/11 07:24 PM
11/16/11 07:24 PM
They are great--If they are straight , have reg ole ARP bolts, and are machined by a good shop they are almost indestructable--and..if you have a race engine most likely you have pretty light pistons so that makes them even stronger--old TRW slugs can kill any combo but I love stock SB rods! 4 small blocks--8 years, 250-300 rounds a year, never as much as a spun bearing!
SIR's have a bad rap but you have to consider that they have been through many versions--first ones had knurled bolts that were not so hot, then a batch was made with tang grooves in the wrong place, and as time went on bolt combos got better.
They are easy to over torque and the bushing quality is questionable--they are light and make one turn like a chainsaw but I have had 3 engines experience failure with SIR's so I don't use them anymore. So...compare good stock rods with bolts to the H Beams out there and stockers win IMO>
Re: stock smallblock rods... [Re: ] #1114870
11/16/11 08:35 PM
11/16/11 08:35 PM
dogdays Offline
dogdays  Offline
Most every failure starts from the outermost fiber, in tension. Shotpeening (not just glassbeading) causes a compressive stress that's locked into the surface, so it takes more tensile stress to start a crack.
Real shotpeening usually uses steel shot and the intensity is specified on the Almen scale.
R.
Re: stock smallblock rods... [Re: Moparnut426] #1114871
11/16/11 11:01 PM
11/16/11 11:01 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Kasey
what is the bearing size of sb ford and how did they do that sounds like alote bull sheet going around
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: stock smallblock rods... [Re: WHITEDART] #1114872
11/17/11 01:08 AM
11/17/11 01:08 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I wouldn't buy SIR rods if you paid me to.
It seems like shot peening is a good idea then...I'd have to price out that and resizing them then to see if they are worth running or stepping up to a brand new aftermarket rod
Re: stock smallblock rods... [Re: Moparnut426] #1114873
11/17/11 01:44 AM
11/17/11 01:44 AM
Minot, ND
darndart Offline
darndart  Offline
Minot, ND
Kasey
I don't beleive this is possible. I've built a couple 347's with 5.4" rod and the wrist pin intersects the oil rings. A 6.123 rod would put the piston somewhere in the middle of cylinder head!
My son's 427/351windsor based stroker uses a 6.125 SBC rod. I could see the Mopar rod maybe used in that combo. But the crank still has a 2.10 SBC jouranl size!!!!
73 Dart Sport 340, 410ci, Indy 360-2 230CNC.
72 Demon 340 4-speed
01 Ram Quad Cab
89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI
86 Mustang GT 5.0 AOD
82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
Re: stock smallblock rods... [Re: darndart] #1114874
11/17/11 12:23 PM
11/17/11 12:23 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
im running stock rods...lightened balanced polished and shot peened,
ive turned the motor 8k by accident a few times a few yrs ago..but motor still runs excellent...
6.67 1/8th last time out...
i went through a bunch of rods trying to get a set of 10 all done up the same...
i had 6 rods left over after doing this prep..
I had a ford guy want those so i got 2 more done to match that left over 6 rods..and sold them to him for 150 bucks..he put them in a ford stroker also...and is happy last i heard?
hold a 340 rod next to a big block chevy rod then youll get the picture..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: stock smallblock rods... [Re: cheapstreetdustr] #1114875
11/18/11 01:29 PM
11/18/11 01:29 PM
dogdays Offline
dogdays  Offline
Back in the day I used an aircraft engine rebuilder to Magnaflux and shotpeen stock rods. This is during the '70s when that was all we had.
R.
Re: stock smallblock rods... [Re: darndart] #1114876
11/18/11 05:19 PM
11/18/11 05:19 PM
Moparnut426 Offline
Moparnut426  Offline
Kasey
Might have been in his other 302 that had an offset ground crank inn it. Now that you say that. The last few 347s i built were way op in the piston also.
Kasey
Re: stock smallblock rods... [Re: mshred] #1114877
11/18/11 08:39 PM
11/18/11 08:39 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Not sure where the limits are, but with proper prep, deburring, peening, and bolts 340 rods have been to 550hp and 8300 rpm.
Re: stock smallblock rods... [Re: mshred] #1114878
11/19/11 12:41 AM
11/19/11 12:41 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Aftermarket rods is a must in high horsepower applications. The lighter the piston, the easier it is on the rod. The shorter the stroke, the better.
Page 1 of 3 1 2 3
