A body power glide users #1112343
11/13/11 12:01 AM
11/13/11 12:01 AM
BigFish69 Offline OP
Is there any fit isues when useing tti 2in header and jw bell with a glide or any floor/tunnel mods.
Re: A body power glide user [Re: BigFish69] #1112344
11/13/11 12:38 AM
11/13/11 12:38 AM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
No,we ran that exact setup...Modification to the stock crossmember is all we had to do...Starter fitment(shims) is a pain,along with removal...Solved the starter issues with a midplate and custom headers.........
Re: A body power glide user [Re: Gary Robbins] #1112345
11/13/11 12:58 AM
11/13/11 12:58 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
How does a mid plate solve the starter removal?
Re: A body power glide user [Re: rowin4] #1112346
11/13/11 10:32 AM
11/13/11 10:32 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
get the converter made with t/f rear on it and i welded a pce of flat on gearbox mount and bolts straight up ,tail shaft length is different also
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: A body power glide user [Re: Ian] #1112347
11/13/11 11:04 AM
11/13/11 11:04 AM
Ian
your saying ptc offers a converter with the starter ring gear attached to the converter. does this eliminate shimming the starter problems ???
Re: A body power glide user [Re: BigFish69] #1112348
11/13/11 11:20 AM
11/13/11 11:20 AM
HOUSTON,TEXAS
FIREGUY12 Offline
FIREGUY12  Offline
HOUSTON,TEXAS
I run 2 inch hedman headers with jw bell no starter fittment issues with the late model small stater. Just make sure you use the jw flywheel kit. They have an adapter with special flywheel bolts. Also the kit has a bushing for the starter nose cone as well as five starter shims. so you will have shim the starter .
Re: A body power glide user [Re: FIREGUY12] #1112349
11/13/11 11:35 AM
11/13/11 11:35 AM
HOUSTON,TEXAS
FIREGUY12 Offline
FIREGUY12  Offline
HOUSTON,TEXAS
Also make sure you use a rubber trans mount when using a midplate or you will crack the glide case. i cracked mine the first pass. now i dont use any bolts in my trans mount. The trans just sitss on the mount. the stock a body mount will work with the glide with a piece of angle iron.
Re: A body power glide user [Re: rowin4] #1112350
11/13/11 01:15 PM
11/13/11 01:15 PM
Idabel,Oklahoma
Idabel,Oklahoma
Less shims to deal with or in some cases with the right thickness midplate none and with custom headers you don't have to remove them to get to the starter...I've always had to shim starters to get the pinion gear on the starter the correct dept on/in the flywheel.....
Re: A body power glide user [Re: BigFish69] #1112351
11/13/11 10:12 PM
11/13/11 10:12 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Ian
they where going to do it with mine ,then they put it in the to hard basket ,and sold me the wheel kit ,and due to a fat scat flange on crank i had to turn down crank spacer any way ,but we do converters with the starter rings on them over here all the time
Re: A body power glide user [Re: Ian] #1112352
11/14/11 01:52 AM
11/14/11 01:52 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
No issues with 2 1/4 Hookers either , mini starter is also a good fit.
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
