Re: A body power glide user
[Re: rowin4]
#1112350
11/13/11 01:15 PM
11/13/11 01:15 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
No,we ran that exact setup...Modification to the stock crossmember is all we had to do...Starter fitment(shims) is a pain,along with removal...Solved the starter issues with a midplate and custom headers.........
How does a mid plate solve the starter removal?
Less shims to deal with or in some cases with the right thickness midplate none and with custom headers you don't have to remove them to get to the starter...I've always had to shim starters to get the pinion gear on the starter the correct dept on/in the flywheel.....
[Re: BigFish69]
#1112351
11/13/11 10:12 PM
11/13/11 10:12 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
Ian your saying ptc offers a converter with the starter ring gear attached to the converter. does this eliminate shimming the starter problems ???
they where going to do it with mine ,then they put it in the to hard basket ,and sold me the wheel kit ,and due to a fat scat flange on crank i had to turn down crank spacer any way ,but we do converters with the starter rings on them over here all the time
[Re: Ian]
#1112352
11/14/11 01:52 AM
11/14/11 01:52 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
No issues with 2 1/4 Hookers either , mini starter is also a good fit. Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
