HID headlights? #1112218
11/12/11 07:24 PM
11/12/11 07:24 PM
Lincoln NE
440forPOWER Offline OP
super gas
super gas
Lincoln NE
Anyone sell a HID kit for old muscle cars? 70 Challenger to be exact. I can't seem to find one. But I've seen a few cars in magazines with them. Thanks
Re: HID headlights? [Re: 440forPOWER] #1112219
11/12/11 08:26 PM
11/12/11 08:26 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I pieced mine together. Got these, 35w 6000k I think and got neolite housings
http://www.ddmtuning.com/Products/Apexcone-Raptor-HID-Kit
Re: HID headlights? [Re: 440forPOWER] #1112220
11/12/11 08:29 PM
11/12/11 08:29 PM
ill
dennismopar73 Offline
ill
At one time all the parts stores could get them some was even in stock, so might call some of them see if they still do?
J C Whitney should have them
Re: HID headlights? [Re: 440forPOWER] #1112221
11/12/11 08:35 PM
11/12/11 08:35 PM
jersey
Spaceman Spiff Offline
jersey
i got these for the wagon
http://www.summitracing.com/parts/HLA-002850811/
Then Just buy a good quality( not a $99 budget) H4 HID conversion kit. People can't believe how much light output there is at night.
Only think is, when you turn on the hibeams, the HIDS go off and ONLY the hibeams come on.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: HID headlights? [Re: 440forPOWER] #1112222
11/12/11 08:56 PM
11/12/11 08:56 PM
kentucky
roadrunner7020 Offline
kentucky
from what ive seen there isnt a kit, people but H4 headlight conversions lights from painless for example. Then you can either make your own relay harness to avoid running all the extra power through the headlight switch or buy the four headlight system harness from hella. Lastly you purchase a HID ballast and bulbs from about anyone online they are all over ebay its how most people convert there current h4 style headlight vehicles to HIDs and then your done.
HELLA H4 575 Lights
Outter lights
inboard lights
Painless 4 headlight system relay harness
Headlight conversion harness
Then all you need is an h4 to HID conversion ballast and bulbs off ebay and your done.
Thats what ive seen most people do on here
Re: HID headlights? [Re: roadrunner7020] #1112223
11/13/11 07:50 PM
11/13/11 07:50 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Just a note to anyone out there wanting to run true HID with ballasts on their Pre-69 hideaway headlight cars.
You need to modify the linkage from the actuator. Cut it, and lengthen the distance on the loop for the linkage. I have the H4 conversion. But when you add the HID conversion kit, the base of the bulb hits the linkage. I have to remove the grille in order to gain access to mine and I am currently not prepared to do that. I even have to move my Hi/Lo headlights to the INSIDE while I relocate the HI to the outside. I think I will get a better wider beam hitting the road. I hardly use the Hi/Lo beams but those will be upgraded to H4 as well so there is uniformity at the headlights and the light output.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: HID headlights? [Re: Pyper70] #1112224
11/14/11 09:10 PM
11/14/11 09:10 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
Call Summit, my son bought a kit, nice install. it was plug and play with the correct wire lengths and all. Uses a relay off the battery and everything else brightened up. Call Summit.
Re: HID headlights? [Re: CYACOP] #1112225
11/14/11 10:53 PM
11/14/11 10:53 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Goto a Mopar guy that knows your cars and knows lighting. Email him with your questions as he has no online cart and has contact with each customer to make sure you get the right parts the first time.
http://www.danielsternlighting.com/
Re: HID headlights? [Re: PHJ426] #1112226
03/27/12 10:18 AM
03/27/12 10:18 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I had some time today, Only a few months since the start of this thread and was checking out Daniel Stern's website out only to find this on HID conversions.
The short version is "Do not do it"
Here is the long version, follow this link:
http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
Re: HID headlights? [Re: PHJ426] #1112227
03/27/12 11:35 AM
03/27/12 11:35 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I bought some inexpensive 7" headlights from eBay a few years back that accept an H3 bulb. Retrofitted some H3 eBay HIDs with a relay in them, they've been good to go.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: HID headlights? [Re: GoodysGotaCuda] #1112228
03/27/12 02:23 PM
03/27/12 02:23 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
With all due respect, this is exactly the WRONG WAY TO DO IT.
Daniel Stern sums it up better than I ever could. I've worked in the automotive lighting industry in product development and manufacturing. He hits the nail on the head and I concur 100% with his article.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: HID headlights? [Re: 471Magnum] #1112229
03/27/12 02:48 PM
03/27/12 02:48 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
For the hour I've driven in the dark over the last three years...it works fine. I am much less concerned with the ideal pattern on a car that sees so very little night driving. Daily driver is a different story..
2020 RAM 1500
