HID headlights?
#1112218
11/12/11 07:24 PM
11/12/11 07:24 PM
Posts: 2,023 Lincoln NE
440forPOWER
super gas
super gas
Lincoln NE
Anyone sell a HID kit for old muscle cars? 70 Challenger to be exact. I can't seem to find one. But I've seen a few cars in magazines with them. Thanks
Re: HID headlights?
[Re: 440forPOWER]
#1112221
11/12/11 08:35 PM
11/12/11 08:35 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
i got these for the wagon http://www.summitracing.com/parts/HLA-002850811/Then Just buy a good quality( not a $99 budget) H4 HID conversion kit. People can't believe how much light output there is at night. Only think is, when you turn on the hibeams, the HIDS go off and ONLY the hibeams come on.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: HID headlights?
[Re: 440forPOWER]
#1112222
11/12/11 08:56 PM
11/12/11 08:56 PM
Posts: 363 kentucky
roadrunner7020
kentucky
from what ive seen there isnt a kit, people but H4 headlight conversions lights from painless for example. Then you can either make your own relay harness to avoid running all the extra power through the headlight switch or buy the four headlight system harness from hella. Lastly you purchase a HID ballast and bulbs from about anyone online they are all over ebay its how most people convert there current h4 style headlight vehicles to HIDs and then your done. HELLA H4 575 Lights Outter lights inboard lights Painless 4 headlight system relay harness Headlight conversion harness Then all you need is an h4 to HID conversion ballast and bulbs off ebay and your done. Thats what ive seen most people do on here
Re: HID headlights?
[Re: roadrunner7020]
#1112223
11/13/11 07:50 PM
11/13/11 07:50 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Just a note to anyone out there wanting to run true HID with ballasts on their Pre-69 hideaway headlight cars.
You need to modify the linkage from the actuator. Cut it, and lengthen the distance on the loop for the linkage. I have the H4 conversion. But when you add the HID conversion kit, the base of the bulb hits the linkage. I have to remove the grille in order to gain access to mine and I am currently not prepared to do that. I even have to move my Hi/Lo headlights to the INSIDE while I relocate the HI to the outside. I think I will get a better wider beam hitting the road. I hardly use the Hi/Lo beams but those will be upgraded to H4 as well so there is uniformity at the headlights and the light output.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: HID headlights?
[Re: 471Magnum]
#1112229
03/27/12 02:48 PM
03/27/12 02:48 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I bought some inexpensive 7" headlights from eBay a few years back that accept an H3 bulb. Retrofitted some H3 eBay HIDs with a relay in them, they've been good to go.
With all due respect, this is exactly the WRONG WAY TO DO IT.
Daniel Stern sums it up better than I ever could. I've worked in the automotive lighting industry in product development and manufacturing. He hits the nail on the head and I concur 100% with his article.
For the hour I've driven in the dark over the last three years...it works fine. I am much less concerned with the ideal pattern on a car that sees so very little night driving. Daily driver is a different story..
