Hood problem #1107426
11/05/11 12:49 AM
11/05/11 12:49 AM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
Sorry for such a basic question, but after I close my hood, why do I always have to push the back of the hood down to get it to be flush with the fenders? (Back by the cowl, that is).
This is a '70 Challenger, AMD bulge hood and stock springs.
Re: Hood problem [Re: Moparmaniacc] #1107427
11/05/11 12:53 AM
11/05/11 12:53 AM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
I was having that same problem with my 1971 'Cuda. Stock hood and 40 year old stock hinges. I bought a new set of hinges that I hope will fix this.
If someone knows a better way, let us both know...
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: Hood problem [Re: Moparmaniacc] #1107428
11/05/11 01:16 AM
11/05/11 01:16 AM
SeventySatellite Offline
Here's a post. I haven't put my hood back on to try it yet.
https://board.moparts.org/ubbthreads/show...rue#Post6820629
Re: Hood problem [Re: SeventySatellite] #1107429
11/05/11 02:35 AM
11/05/11 02:35 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This has been a problem with several "Open Cowl" type hoods. Think of the 70-81 Camaro/Firebirds, the mid 70s impalas, Monte carlos, GM trucks....
Its likely in the adjustment of the hood to hinge bolts.
Re: Hood problem [Re: SeventySatellite] #1107430
11/05/11 07:57 AM
11/05/11 07:57 AM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
I don't think what he is talking about is a hinge installation adjustment problem. I think it is more of a worn out hinge problem.
In my case, the hinges have been on my car for 40 years. They had never been replaced. I really didn't even notice it myself. A friend pointed it out to me because it was happening to his car also. If you close the hood all the way shut, the back corner would have about 1/2 inch sticking up. I would just push down on the corner and it would stay down and not pop back up while driving or anything. This only happened on my back left side. I am hoping new hinges will fix the problem. This is NOT an installation adjustment problem. At least not how I read the original post.
Re: Hood problem [Re: TinCuda] #1107431
11/05/11 11:59 AM
11/05/11 11:59 AM
NJ
rdrnr6970 Online content
Your #1 source for current events
rdrnr6970  Online Content
NJ
i agree,im thinking hinges.
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: Hood problem [Re: rdrnr6970] #1107432
11/05/11 08:36 PM
11/05/11 08:36 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
Only two ways for this to happen. One: at least one mounting bolt is lose on the hinge. Two: the hinge pivots are badly worn.
Tighten all bolts, if it still does it you need a new hinge.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Hood problem [Re: BFASTER] #1107433
11/06/11 12:22 AM
11/06/11 12:22 AM
Northern Virginia
Northern Virginia
Thanks. This has happened ever since I bought the car, but then I took it to a shop to swap gears, and when I got it back it was even worse. The rear of the hood will now stick up a good 2 inches until I push it down!
I will check the hinges and maybe try the adjustment from Resto Rick.
Re: Hood problem [Re: Moparmaniacc] #1107434
11/06/11 02:05 AM
11/06/11 02:05 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Try the adjustment, you might be surprised & it doesn't cost a dime...
Re: Hood problem [Re: 1_WILD_RT] #1107435
11/06/11 08:09 PM
11/06/11 08:09 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And if the adjustment does'nt work then have RestoRick rebuild your 70 hinges...Repops are the 71-74 style...
Re: Hood problem [Re: Moparmaniacc] #1107436
11/10/11 03:55 PM
11/10/11 03:55 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
I got my old hinges off. I have not installed my new hinges yet because not everything is painted. I think that I have a pretty good idea why the hood was acting that way, at least on my car.
If you look at the hinge on the left, the teeth are really worn out. The hinge on the right was acting just fine and you can tell the difference.
Hope this helps.
Re: Hood problem [Re: TinCuda] #1107437
11/16/11 11:47 PM
11/16/11 11:47 PM
Northern Virginia
Northern Virginia
Thanks, I am trying to determine if rebuilding or new AMD is the way to go, pricewise.
Re: Hood problem [Re: 1_WILD_RT] #1107438
11/17/11 11:27 PM
11/17/11 11:27 PM
IMGTX Offline
IMGTX  Offline
