Re: Msd 6al Digital
[Re: joedust451]
#1103097
10/28/11 11:52 AM
10/28/11 11:52 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Also, if not done already, run a heavy red wire from your alternator, directly to your starter relay, or where your MSD 12 v is placed. It not only will ensure high voltage to your MSD, it will not push all the voltage through your firewall stock wiring. You probably have already done this. Just wanted to mention it. Good luck http://www.bing.com/images/search?q=msd+...amp;FORM=IDFRIR
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Msd 6al Digital
[Re: joedust451]
#1103098
10/28/11 04:03 PM
10/28/11 04:03 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Like said, bypass the ballast completely, I run a 10* jumper wire.
as stated, ballast is not required with multi-spark, the coil never has time to heat up enough. to relieve future problems take it totally out of the eguation. alot of guys who want to retain a somewhat stock look dig out the filler in the back of the ballast an run a #10 wire jumper from terminal to terminal.
