Msd 6al Digital #1103094
10/27/11 11:26 PM
10/27/11 11:26 PM
NY
Beep Beep Offline OP
NY
Can someone tell me if I wired this correctly. I installed an msd 6al box, I hooked up the thin red wire to the ignition 1 terminal on the ballast resistor. This connector had one blue wire, and I jointed the red to the blue and left it on the ballast resistor.
The other side of the ballast resistor is ignition 2 and it has a blue and brown wire on it. I left that alone. I know it works but if the resistor burns out will the car run?
Re: Msd 6al Digital [Re: Beep Beep] #1103095
10/27/11 11:33 PM
10/27/11 11:33 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
bypass resistor.
Re: Msd 6al Digital [Re: a493demon] #1103096
10/28/11 12:01 AM
10/28/11 12:01 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Like said, bypass the ballast completely, I run a 10* jumper wire.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Msd 6al Digital [Re: joedust451] #1103097
10/28/11 11:52 AM
10/28/11 11:52 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Also, if not done already, run a heavy red wire from your alternator, directly to your starter relay, or where your MSD 12 v is placed. It not only will ensure high voltage to your MSD, it will not push all the voltage through your firewall stock wiring. You probably have already done this. Just wanted to mention it. Good luck
http://www.bing.com/images/search?q=msd+...amp;FORM=IDFRIR
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Msd 6al Digital [Re: joedust451] #1103098
10/28/11 04:03 PM
10/28/11 04:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
as stated, ballast is not required with multi-spark, the coil never has time to heat up enough. to relieve future problems take it totally out of the eguation. alot of guys who want to retain a somewhat stock look dig out the filler in the back of the ballast an run a #10 wire jumper from terminal to terminal.
Re: Msd 6al Digital [Re: mikemee1331] #1103099
10/28/11 08:56 PM
10/28/11 08:56 PM
NY
NY
Let me understand this better. I want to keep the factory look so I can just leave the wires on the ballast resistor and jumper both terminals with 10 gauge wire.
