Re: Crane rocker carnage pic. Need rocker recommendations [Re: MR_P_BODY] #1101191
10/25/11 12:25 PM
10/25/11 12:25 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
t&d.$$$, but worth it. stay safe, seeya.
thats all I run now... would be the last
set of rockers you would buy
the best money i have spent ,t&d all the way
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Ian] #1101192
10/25/11 04:41 PM
10/25/11 04:41 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
Hello,
t&d's will also break, .650 lift roller 600 lbs spring, have broken 3-4 in 250 runs, they do have a life cycle as t&d says. just broke 1 intake at lvd this past weekend. car has been sitting since may without backing off rockers??
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Crane rocker carnage pic. Need rocker recommendations [Re: '72CudaRacer] #1101193
10/25/11 05:41 PM
10/25/11 05:41 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have the blue Mopar Performance ones that are made by Crane. I broke one this season at just under 7000 RPM's in the lights on 1/4 mile. Mine broke at the same spot, looks identical to yours. I replaced mine with a spare on, and replaced the mangled up push rod, so far so good.
Brian Dunnigan
I am running these same blue mopar performance rockers with a solid roller cam. I hope mine dont do that. Or should I be expecting it?
67' charger 499 RB 10.57 at 127
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Thumperdart] #1101194
10/25/11 09:45 PM
10/25/11 09:45 PM
NC
440Jim Offline
440Jim  Offline
NC
ThumperDart
Exactly, I don`t think the Cranes or Comps were designed for those pressures and that`s why I went to Harlands.............
440lebaron:
Hello,
gary
This is disappointing. The original poster is only running 550 lbs open pressure (his estimate) and the rockers are breaking. There has to be more to it!
-number of runs
-valve float or surge
-etc. or something
Now I agree Harland Sharp or T&D are better, but at 550 lbs open that is disappointing.
And the T&D post is disappointing at 600 lbs open. These are not high pressures, IMO. But I do agree that aluminum doesn't last forever. But I know a bunch of bracket racers that put 300 passes on their cars every season; and they don't buy rockers every year.
Maybe I should just stick to the flat tappet cams and 400ish open pressure... Even the Indy rockers hold up to that ! LOL
What's Up with this????
Re: Crane rocker carnage pic. Need rocker recommendations [Re: dragram440] #1101195
10/25/11 09:51 PM
10/25/11 09:51 PM
Guitar Jones Online laugh2
Brian Dunnigan
I have both the Crane Golds and the Mopar blues and they are not the same.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101196
10/30/11 11:08 AM
10/30/11 11:08 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Harland sharp break too. Not sure but kicked a rod a t same time pulling motor to see if rod caused rocker or exhaust rocker breaking at 7600 caused rod??
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Dodgem] #1101197
10/30/11 11:09 AM
10/30/11 11:09 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
another
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Dodgem] #1101198
10/30/11 11:55 AM
10/30/11 11:55 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I'd be willing to bet you know already why this happened. Rocker breaking, causing a rod to break? Or rod breaking, casuing a rocker to break...hmmmm..decisions...decisions....I know where I would put my money....
How bad is the rest of the damage?
RIP Monte Smith
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Dodgem] #1101199
10/30/11 12:01 PM
10/30/11 12:01 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
This thread is making me nervous now. I have 230 closed 685 open on my springs. crane golds at 1.5 ratio. low .700 lift on eddy rpm heads. I planned on changing the complete top end by summer, but may end up doing it sooner.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Mopar-Al] #1101200
10/30/11 12:31 PM
10/30/11 12:31 PM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
I planned on waiting until next spring since the season is almost over, but Todd (Competitionwedge) gave me a sweet price so I'm getting them now. I may do a little street driving if the weather stays nice. My local track is done after today, but KCIR runs thru November according to their site, so I might try to run down there sometime. I was nervous about the Cranes and had one break. I'm not waiting any longer.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: CompWedgeEngines] #1101201
10/30/11 12:34 PM
10/30/11 12:34 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Just pulling the motor this afternoon maybe finishing later in the week!
Re: Crane rocker carnage pic. Need rocker recommendations [Re: CompWedgeEngines] #1101202
10/30/11 01:13 PM
10/30/11 01:13 PM
Delray beach, Florida
P
Performance Only Offline
P
when a rod breaks and the piston goes slamming into the valves, it's a sure bet that something in the top end is going to take one heck of a hit.
we use Harland Sharps on combo's with over 875lb springs and i've never broken one. IMO they're every bit as strong as the T&D's. the only thing better would be the individual shaft Jesel set-up.
machine shop owner and engine builder
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Performance Only] #1101203
10/31/11 02:27 PM
10/31/11 02:27 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea I fear the piston whacked the valves still working on getting it out? Or should be! :-)
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Scott58] #1101204
11/04/11 01:08 AM
11/04/11 01:08 AM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
RAS makes a very strong rocker in stainless, good if you do a lot of street use. Very expensive, though.
That would be fine if you could call these people and someone
Would answer the phone! They don't return calls or emails. I don't think
Anyone can get these rockers anymore! Lol. I'm sore with these folks..
Does it show? Maybe I'll get my rockers back someday.
74 dart sport 440 www.Csucarbs.com
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Guitar Jones] #1101205
11/04/11 02:24 PM
11/04/11 02:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Brian Dunnigan
Alrighty then... which one is better....
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101206
11/04/11 03:12 PM
11/04/11 03:12 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
reading all the feedback from everyone on here tells me all rockers fail at some point in time. eariler i said have t&d's. i have 625# open. one thing i do when my ride sits for the winter, i loosen the rockers. maybe this helps rocker life??? stay safe, seeya.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: rickraw] #1101207
11/04/11 05:07 PM
11/04/11 05:07 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
I feel that a 620 lift or less flat tappet is the limit for Cranes and hughes. 700 is the limit for harland sharps. Anything bigger needs paired jessel or T&D... Flimsey cheap pushrods will also cause problems. Overkill is the safe way to go when you are building a valve train. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Crane rocker carnage pic. Need rocker recommendations [Re: poppaj] #1101208
11/04/11 11:10 PM
11/04/11 11:10 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Harland sharps r rated up to 900" lift ive just upgraded to a set of Smith Brothers 120 wall/3/8 push rods at the end of the season hoping to eliminate some of the flex in the drive train
Re: Crane rocker carnage pic. Need rocker recommendations [Re: racerx] #1101209
11/06/11 11:43 AM
11/06/11 11:43 AM
ky
68roadrunner Offline
ky
i have broke 3 harland sharps this year for no apparent reason. these are only a season and a half old and they were off the engine over the winter.
i had the kmotion 950 springs set up properly giving me like 720 open. so i switched to a pac giving me 790 open. to see what this would do.
still broke a rocker after the spring change.
so are the rockers weak from previous harmonics or still have a problem
guess new pushrods next. have s.b. 3/8 120 wall now
Re: Crane rocker carnage pic. Need rocker recommendations [Re: 68roadrunner] #1101210
11/06/11 11:54 AM
11/06/11 11:54 AM
Mo.
racerx Offline
racerx  Offline
Mo.
If u r asking me.I have no ideal maybe it's inferior metals r something maybe one of the rocker experts will chime in and answer the?..........
