Crane rocker carnage pic. Need rocker recommendations #1101171
10/24/11 10:52 PM
10/24/11 10:52 PM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
I'm running a solid roller in my 451. The specs are 253/263 @ .050, .610/.610 lift after lash. I believe my spring pressure is in the neigborhood of 550 lbs/in. Luckily this rocker just broke at an idle and the car was shut off immediately. What are you guys using? I need a new set of 1.60 ratio rockers. I like the sound of the Comp Pro-Magnums, but they don't offer them in a 1.60 ratio.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101172
10/24/11 10:54 PM
10/24/11 10:54 PM
Delray beach, Florida
P
Performance Only Offline
P
i'd skip right over the comps and go right to the Harland Sharps. worries over...
machine shop owner and engine builder
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101173
10/24/11 10:55 PM
10/24/11 10:55 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Had the same thing happen to me I went with Harland Sharp
Re: Crane rocker carnage pic. Need rocker recommendations [Re: racerx] #1101174
10/24/11 10:59 PM
10/24/11 10:59 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Ditto.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Crane rocker carnage pic. Need rocker recommendations [Re: racerx] #1101175
10/24/11 11:00 PM
10/24/11 11:00 PM
IN
ahy Offline
ahy  Offline
IN
The Comps would need bronze bushings added to hold up with the spring pressure you are running. I run them and like them but over around 450 lb/.6" lift they can gall without the bushings.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101176
10/24/11 11:04 PM
10/24/11 11:04 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
t&d.$$$, but worth it. stay safe, seeya.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: rickraw] #1101177
10/24/11 11:10 PM
10/24/11 11:10 PM
Bellevue, NE
Bellevue, NE
So does everywhere charge $125 more for the 1.6 Harland Sharps compared to the 1.5's? Mancini, Summit and Jegs all do. Any links to sites that offer T&D or Jesel? I have no idea what $$$ those cost. Thanks!
Re: Crane rocker carnage pic. Need rocker recommendations [Re: racerx] #1101178
10/24/11 11:10 PM
10/24/11 11:10 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have the blue Mopar Performance ones that are made by Crane. I broke one this season at just under 7000 RPM's in the lights on 1/4 mile. Mine broke at the same spot, looks identical to yours. I replaced mine with a spare on, and replaced the mangled up push rod, so far so good.
Brian Dunnigan
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101179
10/24/11 11:15 PM
10/24/11 11:15 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I dont charge $125 more for Harlands....too bad...you just missed my sale a short time ago....drop me a PM...I can help you out...
https://board.moparts.org/ubbthreads/show...e=0#Post6776844
RIP Monte Smith
Re: Crane rocker carnage pic. Need rocker recommendations [Re: '72CudaRacer] #1101180
10/24/11 11:16 PM
10/24/11 11:16 PM
Bellevue, NE
Bellevue, NE
Brian, that looks real familiar! I had a spare rocker around, slapped her on and went racing yesterday. I'm just worried it will keep happening. My car is driven on the street a decent amount.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101181
10/24/11 11:17 PM
10/24/11 11:17 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Call Harland direct and speak with Mike I got mine from him for less than anyone else could do.And I needed him to put together a custom set to boot.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101182
10/24/11 11:26 PM
10/24/11 11:26 PM
Mooresburg, Tn
Mooresburg, Tn
I'm not 100% sure on the cause of my broken rocker (I don't run a lot of spring pressure and a .590 solid lift cam), but I did find the valve cover gasket had sliped up and gotten "pinched" by the valve spring on that cylinder. Possibly coil bind??? Could have just been the rocker failed.
Brian Dunnigan
Re: Crane rocker carnage pic. Need rocker recommendations [Re: CompWedgeEngines] #1101183
10/24/11 11:30 PM
10/24/11 11:30 PM
Mooresburg, Tn
Mooresburg, Tn
Todd is the man! Great guy to work with, and very knowlegable. He keeps stuff we need in stock.
Brian Dunnigan
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Performance Only] #1101184
10/25/11 12:21 AM
10/25/11 12:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactly, I don`t think the Cranes or Comps were designed for those pressures and that`s why I went to Harlands.............
Re: Crane rocker carnage pic. Need rocker recommendations [Re: CompWedgeEngines] #1101185
10/25/11 12:55 AM
10/25/11 12:55 AM
Colorado Springs, Colorado
Dartthunder340 Offline
Todd is great to work with. I would recommend calling him to set you up. I had some issues with my Crane rockers also and switched to Harland Sharps. Good luck.
Better get inside Ma. Looks like a storm's comin'.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: rickraw] #1101186
10/25/11 01:03 AM
10/25/11 01:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
thats all I run now... would be the last
set of rockers you would buy
Re: Crane rocker carnage pic. Need rocker recommendations [Re: MR_P_BODY] #1101187
10/25/11 01:44 AM
10/25/11 01:44 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
T&D's are awesome, but cost a few pennies. Honestly I bought my Harland Sharp's from Performanceonly and have never looked back. I don't run anywhere near the lift you guys do, but still they work well for me.
Mike
1969 Dodge Dart Swinger
Re: Crane rocker carnage pic. Need rocker recommendations [Re: MikeyT] #1101188
10/25/11 01:51 AM
10/25/11 01:51 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a .630 lift solid flat tappet so I dont run the pressure you do but my brother does as he uses a solid roller like you. And we both run these Hughes 1.6 roller tip rockers. They have been flawless for us so far. I have only ran mine for a few months in my new 493 but he ran his all last year and this year so far with zero trouble. Ron
Re: Crane rocker carnage pic. Need rocker recommendations [Re: 383man] #1101189
10/25/11 11:55 AM
10/25/11 11:55 AM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
RAS makes a very strong rocker in stainless, good if you do a lot of street use. Very expensive, though.
Re: Crane rocker carnage pic. Need rocker recommendations [Re: Charger453] #1101190
10/25/11 12:22 PM
10/25/11 12:22 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
You broke one, I'd expect more to follow , plus ditch those springs between them for solid spacers .
